tire selection
08.05.2020 15:11 # 1
how much the tires affect the fuel of the car 15 "16" 17 "---
08.05.2020 15:11 # 2
After changing the total cap of the tire, it can be increased by a certain amount of tire width, and if the amount of the rim differs from the light weight.
08.05.2020 15:11 # 3
xdesign
It also affects the tire's structure. (There is a difference between V performance or double fingernails.) The thin sidewall makes the tire burn less but is unfavorable in terms of both safety and tire life.
08.05.2020 15:11 # 4
There is such a formula in theoretical calculation.
Air pressure in the tire x Area where the tire presses to the ground (Pattern, tire width etc.) x Number of tires = Weight of the vehicle
According to the weight of your vehicle, water results can be drawn from this formula;
1. Small tire and this tire is very inflated,
2. Big tire and little squeezing of this tire,
3. The tire pattern and the tire pattern to be filled in full in order to increase the contact surface of the tire.
4. Big tire and this tire is very inflated and the pattern is selected accordingly.
If we consider the situation to be exaggerated, the pressure changes in the tire of the car traveling on a cobblestone road will also cause a loss of power.
Therefore, the most economical tires are small and pressure tires. Hope it gives an idea.
Koliva 2011-03-24 16:49:29
08.05.2020 15:11 # 5
They teşşekkür ....
