tire selection
08.05.2020 14:15 # 1
fireblade
Hello again.
I want to install 205/40/17 wheels on my car, which I would like to ask our experienced members and 307 hdi users.
cheek grin because of thin?
and will it cause me trouble because I haven't used diesel before?
thank you in advance for your answers :)
08.05.2020 14:15 # 2
1.4 of your vehicle? 1.4 engine diesel ISW 17 assy car increases bleaching fuel consumption .. you can get suitable performance tires. Like kumho vs
08.05.2020 14:15 # 3
fireblade
110 hp car
but !! :) Since it is 110 hp, the shock absorber is very hard :) I am a bit uneasy since
I congratulate those who wear 5 cm bows for 307s :)
08.05.2020 14:15 # 4
H-a-d-i
I think the suspension, which is already small when the 17 big and cheek gets thin, will go based on comfort. 16 ideal.
08.05.2020 14:15 # 5
individual
205/40/17 already small in diameter to 307 (20.5mm)
this tire is for 206. (206 RC)
If you get 17, 205/50/17 makes more sense.
Another option in 215/45/17 is actually.
08.05.2020 14:15 # 6
You should wear a spring after buying a rim tire.
08.05.2020 14:15 # 7
serverumut
Benefit: - Very beautiful just in shape
- Grip will seriously seek
Loss: - Tires are expensive
- Sound and deformation in the front wheels in a short time due to the thinness of the cheek (It takes a very short time, especially on our roads)
- With the thinning of the cheek, the comfort drops to almost no levels
- If you think your vehicle is HDI, it is already low in performance, you will tire your vehicle by making a 17 "rim, a heavier rim and a wheel that requires more power to turn, and you will tire more and more, fuel will decrease and performance will decrease.
08.05.2020 14:15 # 8
I think it's definitely not that thin, but the cheek is really very problematic, especially if you are too meticulous, you can not enjoy your driving because you will run away from the smallest hole against your car, but you will watch the car looks nice, but it is not very mental but of course your decision ..
08.05.2020 14:15 # 9
fourus_06
[QUOTE = individual] 205/40/17 is already small in diameter to 307 (20.5mm)
I agree. Thumbs Up
08.05.2020 14:15 # 10
berko
215 45 17 is good. If you have a light rim or are going to buy it, it will not crash. I don't think it will cause much trouble because it is already a high torque engine. The hardness will increase slightly, the main will not be so hard. On the other hand, it will noticeably improve handling. Some models of Hankook & toyo & yokohama and kumho are good.
08.05.2020 14:15 # 11
neo
The shock absorbers of the 307s are already harsh. most ideal is to use a nice rim with an offset and a soft tire in the original olculer. then comfort is perfectly acceptable, even with 3.5 cm springs.
