tire selection
08.05.2020 17:58 # 1
korkusuz202
hi friends 206 would 195/50 r15 tire be on my car ?? If there are advantages and disadvantages?
08.05.2020 17:58 # 2
VLKNYKSLN
There is no such thing as it is because the size of the tire is confusing for you. Maybe, but the size of the tire should not be confusing.
08.05.2020 17:58 # 3
Increasing the base width will affect the fuel negatively.
08.05.2020 17:58 # 4
AydinBeyol
michelin tires are good. You can select suitable tires on the basis of model brand from the link.
08.05.2020 17:58 # 5
Alicilik
What are the dimensions of your current tire?
If you are using 175/65/14 when you go to 195/50/15
your priority wheel will change
Afterwards, the tire sidewall will fall to a certain extent and you may lose comfort according to the tire you will use.
As the floor width increases, the road grip will increase and the friction will increase, so the performance of the vehicle will decrease, you will try to close it by pressing the gas and your fuel consumption will increase by a small ratio.
This does not mean that if it burns 5 liters, it will be 7 liters and if it is 5 liters, 5.3e çıakr according to your attitude.
08.05.2020 17:58 # 6
omer_tarsus
I think what matters is the tire diameter. When you attach the 185/55 R15 to the vehicle with the original size of 175/65 R14, the diameter will remain the same, only 1 cm wide. The diameter of the 195/50 R15 is smaller but 2 cm wide than the original one. My ex 206 had 185/55 R15 and was pleased.
08.05.2020 17:58 # 7
error
teacher, you will be swearing under 50 cheeks
08.05.2020 17:58 # 8
korkusuz202
thanks for your comments ..
08.05.2020 17:58 # 9
pt206
[QUOTE = errör] teacher, you will be swearing under 50 cheeks [/ QUOTE]
Big smileThumbs Up
08.05.2020 17:58 # 10
webbee
225 50 17 we use what we do)))))))))))))))
08.05.2020 17:58 # 11
cagdascicen
I am thinking of attaching the 307`s Ariane 16`` rim to my 206 vehicle. Can you write the tire size of this rim, masters?
