Tire rubbing
08.05.2020 18:31 # 1
CrimsonChild
Hello, when 3 people sit on the back seat of my 106 car, my finger does not come between the tire and the fender, it still comes when I press the light brake while driving, there is no rubbing sound from the back, but it is not such a small sound, sometimes it comes when 2 people sit, there is a 14-inch Gti rim so I thought it might be ruby . Even if the sport is a bow, the car looks like a stork, not flattened, what do you think I should do?
08.05.2020 18:31 # 2
Bugra
rubber sizes may not be original. In the fender hood, the plastic part has been removed as a result of impact and rubbing and it may be making noise.
08.05.2020 18:31 # 3
yawruaslan
[QUOTE = 307bursa] Let anyone sit back and finish "Big
rear shock absorbers may be gone
Maybe I sat once for 1 year maybe ahaahah
08.05.2020 18:31 # 4
CrimsonChild
It's ridiculous or tire size ..
08.05.2020 18:31 # 5
kuscu38
[QUOTE = 307bursa] Let it sit on anyone back Big smile
Thumbs Up
08.05.2020 18:31 # 6
CrimsonChild
I have no chance not to sit down. We are a crowded family: D
08.05.2020 18:31 # 7
yawruaslan
[QUOTE = CrimsonChild] I have no chance of not seating. We are a crowded family: D [/ QUOTE]
Change the car then :)
08.05.2020 18:31 # 8
CrimsonChild
Thanks for your help, I hadn't thought of it.
08.05.2020 18:31 # 9
Bugra
[QUOTE = CrimsonChild] Ridiculous or tire size .. [/ QUOTE]
I don't understand what is ridiculous?
08.05.2020 18:31 # 10
CrimsonChild
The original is 14 on 14, so if I rub it, I say it's ridiculous. The nation is 18 years old ..
08.05.2020 18:31 # 11
yawruaslan
[QUOTE = CrimsonChild] Originally 14 on top of 14, so if I rub it, I say it's ridiculous. The nation appreciates 18 .. [/ QUOTE]
If you wear 14 and put a thin cheek, it will not be a problem.
08.05.2020 18:31 # 12
muku
There are rubber wedges on the left and right on the rear axle.
08.05.2020 18:31 # 13
outlaw
It is hard to say something without painting.
1- WHAT ARE TIRE SIZES?
2- IS THE REAR TORSION LOW?
3- REMOVE THE CAR TO THE LIFT AND THERE CAN BE A LONG SCREW UNDER THE CAMPAIGN TO MAKE FRICTION TO THE TIRE?
4- REAR SHOCK ABSORBER MAY BREAK ...
08.05.2020 18:31 # 14
kuscu38
[QUOTE = outlaw] IT IS HARD TO SAY ANYTHING WITHOUT PICTURE ..
ClapClap
08.05.2020 18:31 # 15
Ahmet_ach
change the tire 185.55.14 put 4 people in a row sit again again
08.05.2020 18:31 # 16
CrimsonChild
As it appears in the picture.
08.05.2020 18:31 # 17
outlaw
THERE IS NO RUBBER REFRESH BACK MORE THERE IS ANOTHER TROUBLE IN THE AIR ...
THE DIMENSIONS HOW LIKE HOW LIKE THE REAR MUDGUARD CAN HAVE A RIGHT SHARE INTO THE 1 CM ROUND, WHICH MAKES FRICTION TO THE REAR ...
IF IT IS THERE, GO TO THE RESOURCES WHEN USING THEM WHEN I HAVE MADE THAT 195 WHEN USING THE TIRE ...
08.05.2020 18:31 # 18
mstfkys
I think I should look at that fender in the hood, even when 5-6 people get on this vehicle, it should not be shifted even the room does not rub :)
08.05.2020 18:31 # 19
CrimsonChild
Can't be solved without a nap?
08.05.2020 18:31 # 20
mstfkys
If your car is overflowing when 3 people suddenly get over, the shock absorbers are probably gone, have a control dampen the hood if the robots are intact.
Page : / 3
