Tire recommendation for the 206
08.05.2020 18:31 # 1
yasonal
Friends 1.4 What are your tire recommendations for my gasoline car I have the original tire 13 inch Ben 185 55 15
I want to buy 195 50 15 or 15 rim.
08.05.2020 18:31 # 2
jack67
I use 185 55 15, I recommend you do not upset you in comfort and fuel consumption. As it is a little wider, braking and handling increases but it also affects fuel consumption negatively.
08.05.2020 18:32 # 3
BG307
Hankook K110 is the best tire I have used in 195-55-15 size.
08.05.2020 18:32 # 4
Burak
I think that there will be no problem in 190 55 15 my teacher can be used.
08.05.2020 18:32 # 5
samet206
The original tires of the 206 are not 13. / 55/15 is hard to find, expensive but it is the closest to 175/65/14 compared to the original size.
08.05.2020 18:32 # 6
emre_akdag
I use 195-50-15 sports springs in my car, or there is no drop operation at its original level and although my tires are winter tires, it did not notice anything in the fuel. On the contrary, since the hair rim is heavier than steel, there is no fuel fluctuation. Regarding rubbing, even if 6 people get into the vehicle with myself, there is no rubbing (including bumps).
08.05.2020 18:32 # 7
yasonal
So I'm between 185-55-15 and 190-55-15, but I think I'm going to get 185. Well, I guess how should this rim be a light alloy.
08.05.2020 18:32 # 8
Burak
[QUOTE = yasonal] So I'm between 185-55-15 and 190-55-15, but I think I'm going to get 185 .. Well, I guess how this rim will be a light alloy. [/ QUOTE]
No matter which one looks beautiful in your eyes, go here :)
08.05.2020 18:32 # 9
samet206
[QUOTE = yasonal] So I'm between 185-55-15 and 190-55-15, but I think I'm going to get 185 .. Well, I guess how this rim should be a light alloy. [/ QUOTE]
So, whether you like it or not, the model is enough. ET = 20 25. But as I said above, 185/55/15 is an expensive tire, it is hard to find an intermediate size 195/50/15 is more common, for example, 1 month ago, I bought a replica 15 cc rim and a 17,500 TL for 185/55/15 tire.
08.05.2020 18:32 # 10
pusutr
Lassa brand tire price for 185-55-15 is 210 TL today. I bought 4 pieces on the stove for 725 TL. but it is a nice and high quality tire, but it is expensive because it is an intermediate measure.
08.05.2020 18:32 # 11
yasonal
Thanks guys. =) I think I'm going to get 195-50-15.
08.05.2020 18:32 # 12
DeRyCK
I have been using Bridgestone Potenza g3 tires with 15 "GTI rims for 185-55-15 for about 7 years. There are 5 springs in the vehicle, there is no rubbing, but loss of comfort is felt. It is hard to give but the most suitable size for 206 is 185-55-15, but the choice is yours.
08.05.2020 18:32 # 13
emre_akdag
[QUOTE = yasonal] Thanks guys. =) I think I'm going to get 195-50-15 .. [/ QUOTE] Thumbs Up
08.05.2020 18:32 # 14
Alicilik
It is the same in terms of diameter 185/55/15 and 195/50/15. You can't see a serious difference. I recommend 195 bases for handling, but 185 bases will contribute to the economy.
