Tire Pressure Pressures Danger Signals
08.05.2020 15:43 # 1
Michelin Tire Pressure by the Research Danger Signals veriyor.michelin's, September, October and November, across Turkey carried out a total of 6 centers "Correct Air Pressure" that results obtained from the operations, roadway missing tire is alarming against accidents that may arise from air pressure. It was determined that 58% of the 4109 vehicles examined in Afyon, Susurluk, Istanbul Anatolian and European sides, Ankara and Izmir were used with low air tires, and tire pressure was low enough to cause dangerous results in 3 out of 10 vehicles. Low-pressure tires can have life-threatening consequences such as risk of explosion, reduced grip and loss of control on wet surfaces. Low air pressure in the tires can lead to tire degradation, bursts and consequent loss of vehicle control. Due to the reduced contact of the low-pressure tire with the ground, the vehicle's control in the wet surface decreases, causing an inconsistency in steering control. Tire pressure affects the use of economical vehicles as well as road safety. As the tire pressure drops, the rolling resistance of the tire increases. Compensation of the resulting energy loss by the engine causes more fuel consumption. Deficient air pressure also leads to excessive pressure on the tire shoulders, resulting in wear, reducing tire life by up to 30%. In line with its mission to make road mobility safer and more affordable, Michelin aims to extend the role of tires to larger masses, and always warns drivers to regularly check their tire pressures for safe and economical driving. It is recommended to press the tires in air at least once a month and in accordance with the vehicle manufacturer's recommendation before long trips. For this, the tires must be cold, that is, they have been used at a low speed for no more than 2-3 km or have not been used within 2 hours.
08.05.2020 15:43 # 2
A Useful Study I Recommend Anyone Read Carefully.
Thanks ..
08.05.2020 15:43 # 3
okan77
Thanks a lot for sharing
08.05.2020 15:43 # 4
metin
I am now responsive (:
08.05.2020 15:43 # 5
thanks for sharing nice information
08.05.2020 15:43 # 6
very useful sharing I will now regularly check my tire pressures from now on "Applause"
08.05.2020 15:43 # 7
now I'm printing 32 195 * 55 * 15 ... is it normal or abnormal I don't understand it kind of & nbsp; "Grin" & nbsp; sharing koliva is very nice .. seriously i didn't know some things i learned ... especially high speed importance ...
08.05.2020 15:43 # 8
I check out 1 morning a week. That's why I press 33. If you ask the bookkeeper, he says 30 good times.
08.05.2020 15:43 # 9
then I'll do it, I will print 4 tires 32, I will check every week Saturday, let's see how I get up and down in 1 month ... I'll share the situation with you & nbsp; "Grin" by_ersin 2011-06-28 13:30:05
08.05.2020 15:43 # 10
Tire makers, even service workers, do not know the right situation.
The tire pressure varies according to the vehicle. The most beautiful is to take the value written on the door pillar. If the original dimensions are not used, then the tire should be reduced or increased according to the size or smallness. The larger the tire volume, the more air must be blown (compared to the original).
koliva 2011-06-28 13:34:24
08.05.2020 15:43 # 11
"Thumbs cecoli maybe those tire trials might be related to this weather event ... how about ??
08.05.2020 15:43 # 12
[QUOTE = by_ersin] "Thumbs cecoli maybe those tire trials might be related to this weather event ... how about ?? [/ QUOTE]
& nbsp;
No, no brother ... I wish it was, but it is not. If I hit the same side with 33 and again :)) at 35, it will not change. There is no harm in trying ... "Blink"
& nbsp;
Before I went to Sapanca, I pressed 33 in the morning ...
CeCoLi 2011-06-28 13:38:47
08.05.2020 15:43 # 13
hmm .. i forgot about excitement anyway :) anyway .. your vehicle is a lot heavier than my vehicle.33 normal you .. if i press 33 it feels like my jumping ..... let's see.
08.05.2020 15:43 # 14
some tire guys, who knows what is the benefit of nitrogen pressure?
08.05.2020 15:43 # 15
A nice sharing. Thanks.
08.05.2020 15:43 # 16
[QUOTE = ose307]
some tire users, who knows what is the benefit of nitrogen pressure? pros and cons were discussed. I recommend you take a look, there is a lot of good information.
http://forum.peugeotturkey.com/forum_posts.asp?tıd=13072&kw=nitrojen&pn=1&title=lastiklere-nitrojen-gaz Reviews
08.05.2020 15:43 # 17
There is a table under the air machines in gas stations that shows how many psi should be printed according to the size of each tire.
08.05.2020 15:43 # 18
I agree exactly .. even if all the bids are intact, we can comfortably press the air ... what is my chance, whichever one I enter, is out of order ...
08.05.2020 15:43 # 19
[QUOTE = by_ersin] exactly agree ... even if all the bids are intact, we can comfortably breathe the air .. what is my chance, whichever one I enter, most of them come out defective ... [/ QUOTE]
There is another dimension. There will be a difference between the air you will hit in one station and the air you will hit in another station. Because the mechanism that creates the air pressure in the pump differs little from pump to pump. I think the control of the indicators of these pumps is not done anyway. Reviews
08.05.2020 15:43 # 20
I entered a station that I found on the road, first I pressed the left tire, then I looked, the machine's indicator is not working, I called the officer, the brother did not work, said the eye decision, press the air, did you swear? My stuck eyes jumped up and think about what I thought about that officer at that moment. "Evil
Page : / 2
