Tire for 206 (help)
08.05.2020 18:21 # 1
staticxxx
Friends, I have a subject on my head.
195/55 / R15 cheek height => 195 * 0.55 = 107.25
175/60 / R15 cheek height => 175 * 0.60 = 105
is the above account correct?
I have 195/55 / R15 in my car. if I replace it with the other, my car will drop 2.25mm now?
It gets stuck in my head. I would appreciate if you help.
08.05.2020 18:21 # 2
Turgay_66
[QUOTE = staticxxx] Friends, I have a subject stuck in my head.
[/ QUOTE] 175 60 15 looks like a bike wheel, teacher, thin base 60 sidewall 15 wheels don't look nice, I don't think there are 175 bases on 15 wheels.
08.05.2020 18:21 # 3
staticxxx
http://www.hepsiburada.com/liste/dunlop-175-60-r15-81h-sp-sport-lm703/productdetails.aspx?productıd=otysf778050&categoryıd=259720&navq=categoryid%3d259720%26fh_view_size%3d12%26fh_sort_by%3d- order_stock_attribute_pl 252C%% 252bmin_actual_price_pl% 26sc% 3d8% 26fh_secondid% 3dotysf778050 26fh_lister_pos%% 3D0% 26fh_locatio% of 3d 252F%% 252fcatalog01 252ftr_t% 253d% 252f208905% 257b15%% 257D% 252fcategories% 253C% 257bcatalog01_60002705% 257D% 252fcategories% 253C% 257bcatalog01_60002705_2147483631% 252fcategories%%% 257D 257D 253C 257bcatalog01_60002705_2147483631_259720%%% 26fh_refview is 3dlist
I think I will buy this tire. those who use it says well.
08.05.2020 18:21 # 4
staticxxx
http://do.ngs66.ru/advert/categories/auto/wheel_discs/wheel_with_discs/summer/r15/?id=1861300128
teacher, look at the bidet water site. They took detailed photos. They wear this tire on the Nissan Micra. I think it looks fine.
195 base is tiring. 185 floors are also very expensive. 175 I say enough.
08.05.2020 18:21 # 5
Turgay_66
I don't know much about the tire, I just wanted to say that the tire 175/60/15 will not look good in the car, I use 195/55/15, I think you should make the wheel 14 first
08.05.2020 18:21 # 6
staticxxx
[QUOTE = Turgay_66] I don't know much about the tire, I just wanted to say that the 175/60/15 tire will not look good in the car, I use 195/55/15, I think you should make the wheel 14 if you are tiring the car [/ QUOTE]
I can't break it on the wheels. cms C7 15 inch looks like too.
08.05.2020 18:21 # 7
Turgay_66
[QUOTE = staticxxx] [QUOTE = Turgay_66] I don't know much about the tire, I just wanted to say that the 175/60/15 tire will not look good on the vehicle, I also use 195/55/15, I think you should make the wheel 14 first if you think it is tiring the car [/ QUOTE]
[/ QUOTE] teacher, after all, it's your pleasure.
