tire compatibility
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Old Models
08.05.2020 16:21 # 1
206xr43
Friends my current tire size is 195x45x16 (summer), & nbsp; & nbsp; Would it be if I put on 205x55x16 (winter) tires?
08.05.2020 16:21 # 2
If the vehicle's current tires do not touch the fender, there is a possibility that they will touch because they will increase by 2 centimeters
08.05.2020 16:21 # 3
206xr43
If my teacher Ilhan is going to rise 2 cm, I think it's okay because I have a distance with the current tires.
08.05.2020 16:21 # 4
[QUOTE = 206xr43]
If my teacher Ilhan is going to rise 2 cm, I think it's okay because I have a distance with the current tires, I even put a photo of the car today, I would appreciate if you make a maintenance comment ..
it doesn't touch if we compare it to that vehicle, but the third person shouldn't sit back & nbsp; "Grin"
08.05.2020 16:21 # 5
voodoo
My friend, the tire you are wearing now is 195 45 16 and instead of 205 55 16, maybe this will not cause any problems in your vehicle, but you will be wrong about the speed you have gone ... the speed you see in the indicator is different with the speed you have gone ... You need to wear rubber .... For example, you need to use 55 15 or 65 14 gigi gauges instead of 45 16 ... how happy if I could help & nbsp;
08.05.2020 16:21 # 6
voodoo
[QUOTE = voodoo] my friend, the tire you are wearing is now 195 45 16 and instead you will be wearing 205 55 16 this maybe it will not cause any problems in your vehicle but you will be wrong about the speed you have gone ... the speed you have gone through the indicator will be different ... You need to wear rubber in the same measure or proportionally .... For example, you need to use sizes such as 55 15 or 65 14 instead of 45 16 ... happy if I could help you & nbsp; [/ QUOTE]
