Tire Airs
08.05.2020 20:56 # 1
kayaca
I have 206 vehicles, rear torsion lowered, there are sports springs in front of them. If we drop the air of the wheel, is there any situation where the vehicle is close to the ground? or getting the air of the tire a problem on the road?
08.05.2020 20:56 # 2
The brake definitely increases - the grip is reduced, the chance of the tire tearing increases. The tires will not be close to the ground by decreasing the air. We are going on 4 wheels already, you can put your life in the life of the family by doing such applications, brother. Lowering the pressure values that should be absolutely.
08.05.2020 20:56 # 3
kayaca
How much do you need to do, hodja? 55 cheeks 15/55/185
08.05.2020 20:56 # 4
There were values that should have been on the door of the driver. Brother should have a label. 2.3 bars.
08.05.2020 20:56 # 5
kayaca
Should we print 33?
08.05.2020 20:56 # 6
kayaca
There is a situation like this, how much we press the car does not get sound inside, I thought it would be a little more comfortable if we leave it dim and not yawning in the pits.
08.05.2020 20:56 # 7
OguzhanKucuk61
You are obviously not familiar with this, teacher. It is useful to listen to people who know. What you propose to do can have very serious consequences. You have to print whatever the value on the door.
lowering the air of the tire to lower the car means going on the rim.
lowering the tire's air disrupts its linearity on the road. increases your braking distance. increases fuel consumption.
Also, if you lower the air, you will get more tire and road noise as the point touching the ground will increase.
oguzhankucuk61 2018-06-22 14:41:12
08.05.2020 20:56 # 8
maximusti
this video helps answer the question ..
[TUBE] nklpspxzbvg [/ TUBE]
08.05.2020 20:56 # 9
Kysr038
I was going to throw the video already full maximusti.
You can learn how dangerous it is by watching the video
08.05.2020 20:56 # 10
x571
[QUOTE = rock] We need to press 33 [/ QUOTE]
you set the tool on the gas station to 2.4 bar.
08.05.2020 20:56 # 11
kayaca
thank you, sentence
