TIRE AIR PRESSURE, FRONT ORDER, SUSPENSION ADJUSTMENT
08.05.2020 13:58 # 1
TIRE AIR PRESSURE, FRONT ORDER, SUSPENSION ADJUSTMENT CHARACTERISTICS Tire Air Pressure Selection The following table contains tire air pressure recommendations for performance driving. Vehicle Type Position Pressure Front Wheel Drive Front Rear 35-45 psi30-40 psi Front Engine / Rear Wheel Drive Front Rear 35-45 psi30-40 psi Rear Engine / Rear Wheel Front Rear 35-45 psi35-40 psi In rainy weather, wet roads, 5 to 10 psi higher than dry it is recommended to use air pressure. This will reduce the aquaplaning effect and facilitate the discharge of water from the tire channels, creating a positive effect on road holding. Small Rear Tire Widths SmallerLarger Front CamberMore Minus Plus Plus Rear CamberMore Plus MinusFront Toe OutwardInward Rear Toe Inward Outward Front CasterMore Plus More Minus Front SpringsSofter, Firmer Rear Springs More TougherSofter Front Bend Balance Bar Smoother, Thicker Rear Springs, TougherSofter Bend Bend, Thinner, Thicker, Rear Springs, Tougher, Smoother, Bend, Stabilizer, Thinner Thick, Thinner Weight Distribution Back to the Triumphant Trivia for the Frontline Information Thank you Deran TUYNER
08.05.2020 13:58 # 2
sinan-s
Thanks for the information
