Tire Air Pressure Emergency Aid
08.05.2020 15:07 # 1
Hello friends. I said let's take a look at the tire weather before setting off on the long road today. I bought the tires for the winter, Hankook Winter I-Pike winter tire. It made the road feel great and the car was officially bouncing off. I looked at the tire pressures 38. I was very surprised, I was wondering if it was pressed for winter tires, but I could not make sense. My leg 32. Whatever it was as I wanted. So what is the correct air pressure, how many do you think should be? (Tires 175/65/14)
08.05.2020 15:07 # 2
When you open the driver's door, it writes at what value you need to hit the air behind. The important point here is that there are two different types of metrics. the 38 or 32 psi you are talking about. At the door, it usually writes bar value. I have 307 and it is written that they have to be 2.5 bars. If there is a bar in the indicator of the pump in the station where you are going to hit the air, you will hit the value there, but if it says psi, you must multiply it by 14.5. So this means that 2.5 bar = 36.25 psi (for 307)
Koliva 2011-02-21 17:50:23
08.05.2020 15:07 # 3
My original tire size is 165-65-14 and mine is 175-65-14
08.05.2020 15:07 # 4
[QUOTE = berkaygr] My original tire size is 165-65-14 and mine is 175-65-14 [/ QUOTE]
There is an example site at the bottom. From there you can find the size and see the recommended tire pressure. As you can see, the table is made for the Golf 1.6 Trendline vehicle. Compared to you. By the way, for example, 220 kPa = 2.2 bar.
http://www.nokiantyres.com/recommended-tyre-inflation-pressures
08.05.2020 15:07 # 5
Then I printed it right :) Thanks.
But of course these summer tires, that is, summer tires, I hope there is no difference in winter tires.
08.05.2020 15:07 # 6
The tire dimensions of my car are 175-65 r 14. 14.5 * 2.4 = 34.8. I'm printing 35. If you are going to go the long way, you should press 35.
08.05.2020 15:07 # 7
tugrahan
pressed a little more in the winter tire to open the vacuums
