tire air pressure ???
08.05.2020 19:03 # 1
dogan
Guys, I'm about to go crazy, there is nothing more complicated than this tire issue. 307's factory data says 2.2 bars or something on the doorstep, but I look at the tire tire, the tires are too low. It should be 3.0.
Bidet rear tires 3.0 fully visible even 3.2 still looks a bit low in the front. If anyone knows about this, please help
08.05.2020 19:03 # 2
monalos
My head was hurting too much, the tire is constantly coming down in the air I look at the front 32 psi at the back 32 but the front looks down, this is because the front is heavier than the engine. that is, press the original pressure of the tires 32-33 psi anyway, don't look at the tires any more :), if you say the bid is going down continuously, the nitrogen bass tire is not both warm and lighter than air nitrogen then the tire does not look too low, also 2.3 bar 33 psi coincides 3.3 bar 40 psi then rubber silver :), 175-65-14 bnm tire
08.05.2020 19:03 # 3
muro_60
all of them make it 30 soft, as soon as it knocks, it looks like it is swollen because there is no load on the back.
08.05.2020 19:03 # 4
Eric Cartman
Hodja, I think you have mixed the units of measurement.
1 bar = 14.5 psi
Simply press 32 psi on the front and 30 psi on the back.
08.05.2020 19:03 # 5
ahmet_bjk
If the vehicle has original size tires on the vehicle, it should be used in the values recommended by the company written on the door of the vehicle. The front tires appear low because the engine is at the front and therefore the front is heavier.
If you hit the tire with more air than the factory values, it will both weaken the grip and cause the tire to wear out regionally and more quickly.
The most accurate information is the information provided by the manufacturer.
08.05.2020 19:03 # 6
Adem Kurtuldu
I know 30 is ok too
08.05.2020 19:03 # 7
BLACK LION
I tried them all in time. Press all 4 tires 30. It bounces on top of it and slips in the head. All six reduce traction. I would recommend that I have used this value in all my cars for almost 20 years. Of course, if you use standard size tires in 307.
