Tire advice.
08.05.2020 15:28 # 1
monur
Friends, I am thinking of changing the booties of the car. I am in search of tires to fill the mudguards with soft, performance, minimum noise to be attached to the tin 14 wheels. The size of 15 and 16 tires is wide, but the 14's are now history.
08.05.2020 15:28 # 2
if you can find yokohama c. It is a very nice tire ... only knows the yokohamay.
08.05.2020 15:28 # 3
monur
If you can find [QUOTE = CeCoLi], I would recommend yokohama c. It is a very nice tire ... only knows the yokoham. [/ QUOTE]
Unfortunately, Cem did not have a dealer around here. I can try to get it out, but now the rear tires do not seem to fill the fender (the most stiff case).
08.05.2020 15:28 # 4
Was your original size 175 or 185? What does it say at the door of Sofor? the rest is 65 14 already :))
but as long as the rim has not changed, there is not much you can do. You can get 195 60 14 if you ask me to expand the base. no problem
the cecol 2011-05-25 10:55:05
08.05.2020 15:28 # 5
Sırıtma I now have 195 * 50 * 15 tires attached to my tire :) one tire prevents 31 rear tires 32 dio one all tires 32 bass dio ... actual air size Ouch
08.05.2020 15:28 # 6
metin
Honor brother, I did a lot of research before buying tires.
nokian i3 (H) or nokian H (H) (nokian is the quietest tire in the world, but a bit difficult to find.)
bidet yokohama c. I would recommend the drive The room is just behind the same as the quality of the silence that comes close to the same.
08.05.2020 15:28 # 7
nteker
So how is nokian i3 (T) not the same as room H?
08.05.2020 15:28 # 8
monur
I think Nokian said that it performs very well in light commercials and it is a tire we use in company vehicles. It is important for me to be as soft as silent, and for me, the already delicate front teams give up quickly. Meanwhile the tire size is 175.65.14
08.05.2020 15:28 # 9
I'm printing 34 for 185 * 65 * 14, 3% smaller than the original size of your measurements, and you also need to print 33. For the necessary comparison; http://www.lastik24.com/default.asp?gb=hesap
Important Note: Sizes 3% larger or smaller than your original tire diameter are not recommended by any company in terms of fuel consumption, road holding and brake safety. ( Excerpt from www.bmwteam.net site) 3.4% increase in your measurements.
[QUOTE = You by_] Sırıtma I now have 195 * 50 * 15 tires attached to my tire :) one tire prevents 31 rear tires 32 dio one all tires 32 bass dio ... actual air size Ouch [/ QUOTE]
badires 2011-05-25 11:41:59
08.05.2020 15:28 # 10
Honor, I told you what you need. 195 60 14 more seated :))
08.05.2020 15:28 # 11
[QUOTE = badires]
He should have been 195 55 15. he must have written 50 by mistake.
I converted the new 195 55 to 15. I pressed 33 ...
08.05.2020 15:28 # 12
[QUOTE = cecol a] [QUOTE = badires]
Is it okay to do this?
08.05.2020 15:28 # 13
Onur
If you can find [QUOTE = CeCoLi], I would recommend yokohama c. It is a very nice tire ... only knows the yokoham. [/ QUOTE] Thumbs Up yokohama is the only tire brand that does not need advertising. good tire can be a drive or can be continental premium contact 2 according to your budget
08.05.2020 15:28 # 14
If you can find [QUOTE = Honor] [QUOTE = CeCoLi], I would recommend yokohama c. It is a very nice tire ... only knows the yokoham. [/ QUOTE] Thumbs Up is the only tire brand that does not need advertising yokohama is a good tire can be a drive or can be continental premium contact 2 according to your budget silent tires [/ QUOTE]
Exactly, brother :)) knows the yokohamma who really understands the tire. I did not know, so I fitted the 185 60 14 C drive tire to my previous vehicle on the back of our brother. It is 80.000 km, but still more beautiful. roadbrake brake pull excellent ...
technology is very good. it is not a rubber that everyone knows. lonely like michel is expensive
08.05.2020 15:28 # 15
[QUOTE = You by_] [QUOTE = cecol of] [QUOTE = badires]
no click no sound ... you will not believe it, but it was also more comfortable than the old 185 65 14. At this point, it is very important that the tires are soft. Of course, the fact that its tires were stiff caused this much difference.
known brıdgestone b330 is a rubber tire. but really like a stone Sırıtma asphalt hangs b330 as soon as it hangs :))))))
08.05.2020 15:28 # 16
[QUOTE = cecol of] [QUOTE = You by_] [QUOTE = cecol of] [QUOTE = badires]
then what i understand is that .. you are dior .. if the tire is soft, 33 bass and 4 of them will not be clicked .. but if your tire is hard 30 drops if you drop 28 ze is doomed to blunt .... I understood ... then urgent me tire advice Sırıtma
08.05.2020 15:28 # 17
metin
[QUOTE = nteker] So how is nokian i3 (T) not the same as room H? [/ QUOTE]
Models with T are safe up to 190 km / h,
Models with H are also safe up to a speed of 210 km / h.
text 2011-05-25 12:05:42
08.05.2020 15:28 # 18
metin
[QUOTE = monur] I think Nokian said that it performs very well in light commercials and it is a tire that we use in company vehicles. It is important for me to be as quiet as it is quiet. Meanwhile tire size is 175.65.14 [/ QUOTE]
I am using abi nokian i3 (H) you believe the slowing lines on the road were shaking so much that they are no longer felt. I am very pleased.
08.05.2020 15:28 # 19
ersin brother quotes too long, let's reset the bar :))
If your tires have the need to change, you will.
I bought the new tires. I bought kumho ecsta spt (ku31) because my material is not enough. Reinforced sidewall, reinforced and rim protector.
The tire can be tried very soft and soft. its comfort was like cotton. The brake is very nice in the bend. I haven't had the opportunity to try it on wet. but I can say that it was not enough to have used C.drive before. but it is a good tire for money. they meet the needs of many parts. just like the moment that will reach the vehicle's luminaries, it leaves its back light in the reaction of the steering wheel.
when I asked yokohama 245 TL list :)) 200 I bargained hard. and C.Drive 2 model
08.05.2020 15:28 # 20
YOKOHAMA to your car. As he said in the ad. I have never used it, but there are many who recommend it.
Page : / 3
