tire
08.05.2020 18:16 # 1
batuhan9292
I bought my car 2 years ago, it was flat, they cut it from the helix, but now I started to be very uncomfortable, I will raise and raise my car 2 spirals ... my car has 185 55 15 tires on it. Do you?
08.05.2020 18:16 # 2
omer_tarsus
It is okay in appearance, but the tire you will wear is 4 cm higher in diameter and can make your vehicle bulky on departures. In addition, when the vehicle travels at a speed of 90 km, there will be a different value such as 87-88 on the display. Of course the decision is yours to try.
08.05.2020 18:16 # 3
Bugra
The vehicle is 4-door 206 I think. if so, your car's original tire size is 175/65/14. if you install a smaller or larger tire than the diameter of this tire. You mislead your km counter. If it is large, there may be rubbing into the fender. the vehicle's stance changes. etc.
It is best to get the original coil spring, but for the 15 rims, the tire suitable for your vehicle is the 185/55/15 tire size of the 206 gti.
If it wears 185/65/15, I doubt if it fits in the fender, the vehicle rises close to 4 cm, that is 3.8 mm more than the actual diameter.
08.05.2020 18:16 # 4
batuhan9292
thanksrr :)
