timing sound
08.05.2020 19:20 # 1
omera
Hello friends
I bought the car today ... the master has changed the timing belt. my strap 1.6mm belts on the market were 1.7mm wide. He said he's doing it because of that. He says he's wearing a 1.6mm strap and wearing it. I changed it in circulation.
master says I wear the old strap, the sound is cut off;
The evening started again in the vehicle. but this time it makes noise at idle, it is cut to light gas pressure. this time there is no sound of bearing as if it is in diesel car mode ... there is no tube in my car ..
08.05.2020 19:20 # 2
teacher to make valve adjustment
08.05.2020 19:20 # 3
omera
teacher, this process is laborious and costly ...
08.05.2020 19:20 # 4
he has to make him a master, after all he changed the triger, he gave him a lot of money, he had to do it for free. It is a matter of fine tuning, which requires effortless mastery.
08.05.2020 19:20 # 5
omera
I do not want to entrust my car to that man again. I'll look elsewhere. but is it normal to change valve settings after timing change?
08.05.2020 19:20 # 6
yes it will break. I just changed it, my master even said his own 1000 km, let's make a valve adjustment. i haven't gone yet i will go tomorrow morning
08.05.2020 19:20 # 7
omera
Do you have a master that you can recommend?
08.05.2020 19:20 # 8
Well, my master is actually ford special service but it is good in business. there are places that will not break, but there are friends who will recommend peugeot service in Ankara.
08.05.2020 19:20 # 9
muhammed.ceyhan
Hello friends. I was interested in seeing the subject. When I first bought the vehicle, I changed the timing. About 2 years ago. But valve adjustment was not made. Is it necessary to adjust the valve when the timing changes? My vehicle works like a diesel. In fact, when there is an excess of veteran while the yokus is coming out, a sound similar to the whistling sound is heard.
By the way, my car is 2000 model 1.4 gasoline + 206 xr with lpg the muhammed.ceyh 2015-06-26 22:10:32
08.05.2020 19:20 # 10
omera
Does it sound like idle, you are like a diesel car .. it was just like that ..
I officially regret that I was caring. I will go back to the master tomorrow
08.05.2020 19:20 # 11
muhammed.ceyhan
Rolentide is coming. Looks like ...
08.05.2020 19:20 # 12
omera
Is this sound for 2 years? How is fuel consumption, teacher
08.05.2020 19:20 # 13
omera
I left the master to the car ... he said not from the valves .. he will look ... there is no sound under the engine cover anyway ..
Such things cool the person out of his car .. but I will do it in a way I will do it.
08.05.2020 19:20 # 14
muhammed.ceyhan
[QUOTE = omera] Is this sound for 2 years? How is fuel consumption, teacher
It is not 2 years, but it has been for a long time. Fuel is good. The LPG also has 16 17 krs
