timing set ball change
08.05.2020 16:28 # 1
rhcpeppers
1 week ago, friends started to hear sound from the timing belt as a result of intense oil. Today, 2 balls have changed. I paid 180 liras. how do you think?
08.05.2020 16:28 # 2
Ucyuzalti
What to do with the rain & nbsp; there?
08.05.2020 16:28 # 3
rhcpeppers
I don't know, but I guess he didn't get silenced yet. as a result I'm trying to understand more than 180 lira
08.05.2020 16:28 # 4
badcombatant
The wetted timing is not the belt & nbsp;
08.05.2020 16:28 # 5
Ucyuzalti
I think v is apricot & nbsp;
08.05.2020 16:28 # 6
06OzGuR06
It may have been due to the amount of moisture in the air.
But I know that the timing belt does not sound.
The price is good for the timing belt. High for the V-belt.
08.05.2020 16:28 # 7
Ali
Please replace the timing set with the original parts in the service.
08.05.2020 16:28 # 8
Ucyuzalti
I think the balls of the V-belt are more and more, I changed the one, I gave 15 lira workmanship, 30 tly in the piece, I think & nbsp;
08.05.2020 16:28 # 9
rhcpeppers
I don't know which one. But when the bonnet is opened, the strap that starts to rotate as soon as it runs left. I don't know if there are any other rotating straps. but it has to be the timing. His 2 balls have changed. It should be 60 liras each.
08.05.2020 16:28 # 10
rhcpeppers
http://www.google.com.tr/imgres?q=peugeot+triger+kay%c4%b1%c5%9f%c4%b1+206&um=1&hl=tr&biw=1356&bih= 606 & amp; cpc = isch & amp; tbnid = I q9ytwucan6wfo: & amp; imgrefurl = http: //tardigrad.blogcu.com/arabam-2001-peugeot-206-xr-presence-1-4i/5339200& docid = ojxgm52fn6jbkm & amp; imgurl = http: //img209.imageshack.us/img209/9778/dsc06070.jpg&w=640&h=480&ei=kbnzTu-NBITOsgaisYEI&zoom=1
In this link the red cap is not just six timing ground
08.05.2020 16:28 # 11
okan77
Not ...
08.05.2020 16:28 # 12
06OzGuR06
The V-belt you are talking about is also called the air conditioner belt, alternator belt.
The price is high for this belt. This belt is not a very expensive belt and its replacement is very simple and it does not have expensive workmanship.
< br> So the belt you are changing is not the timing belt ..
06ÖzGüR06 2011-12-23 03:13:36
08.05.2020 16:28 # 13
sahin-peugeot
the ball you have changed is not a timing, if it is a timing, there is 1 bearing in your timing, you have changed the
alternator balls 180 TL exaggeration price by the way
08.05.2020 16:28 # 14
rhcpeppers
I gave 180 pounds 1 day later, the voice started to sound again. I'll go and show it again tomorrow. Reviews auspicious ..
08.05.2020 16:28 # 15
albayman
In order to reach the timing belt
, a lot of protection and parts are removed. therefore, water does not reach triger. The timing belt and its bearing are toothed, even if the error is reached by accident, it is not flat, so it does not make sound that does not slip. If it slips anyway, the car will not start, it will cost a ton & nbsp; it opens. they are cheap too. You gave a lot of 180.
08.05.2020 16:28 # 16
Fatih Ceyhan
The problem has not been solved anyway, I think you should look for your right, we do not find the money on the road. & nbsp;
08.05.2020 16:28 # 17
albayman
that is why don't trust the repairman, when you find the problem, get the part & nbsp; prices and go to the research, find the original at an affordable price and insert the bill into your eye. of course, do this to opportunistic services. Of course, we wouldn't say anything to the person who does his job like a man. But there is also the necessity to be at the beginning of the vehicle in vital part changes such as timing. so that they don't swallow the v-belt as a triger when you go ...
08.05.2020 16:28 # 18
rhcpeppers
where I am, friend's brother-in-law .. & nbsp; I mean, if there was no room;) when it came to the sound again, we went again, they took off, the sound went away. The next day, there was a sound again. we went again today with the friend. Friend paso next to me;) They couldn't understand they looked. They look at the belt and they have no problem with their teeth. they changed it anyway, i loved it for 30 lira. familiar after all;)) Let's see if it will sound again tomorrow morning. Reviews
