Timing Set and Circulation Change
26.11.2021 00:42 # 1
emrebaki
hello friends
2006 I am using 1.4 8 valve feline. I need to change the timing belt. When I look at the original strap, the gates dayco comes out, it says you don't need to spend a lot of money, but I still think there is a difference in quality. I think I would prefer valeo in circulation. Imported products such as airtex are recommended. I think I will give the easiest choice when buying a v-belt Smile. I would be glad if you share your thoughts on the subject.
26.11.2021 08:39 # 2
Hello,
When I had the 2007 fever 206, I bought the timing set Gates, and I bought the circulation pump from a German brand. It was not a problem. Cantinental v-belt can be preferred.
