Timing problem EMERGENCY
08.05.2020 20:08 # 1
hzr206
Good evening everybody, I started my car after it snowed in Istanbul and the sound of the timing belt of my car was coming, then I said it was cold, I did not get stuck too much. and if there are someone who makes this timing set at an affordable price in Istanbul, I would be glad if you could help.
https://www.youtube.com/watch?v=cn-0ozgjrkq&feature=youtu.b to
[TUBE] CN-0ozgjrkq & feature = as youtu.be A [/ TUBE]
08.05.2020 20:08 # 2
Mrttt53
My brother knows that it is not the timing that appears in the video, but the charge apricot. It sounded like the water pump is coming from there. I changed it to 206 hdi 550 lira (pump + set + lathe to where the belt was installed) ina brand was a little bit pile, but the original balls are ina. I guess it would be 400 because it is hard to find workmanship below 100 150 in timing. Mrttt53 2017-01-13 08:44:42
08.05.2020 20:08 # 3
hasayduman
Good Morning
I am going to either the Peugeot Ali or Team Oto in the Eagle Auto Industry, I am very pleased.
team auto senol brother helps in a very helpful and descriptive way,
I think you need to show it to a master,
Get well soon..
Your information.
08.05.2020 20:08 # 4
My teacher sounds like a v-belt but if you want to be comfortable, if you do not know what the last time you have changed, it is useful to change it, as our friend says, it is difficult to find workmanship under 150-200 TL. The prices are down in the following lines.
http://www.peugeotmarket.com/peugeot-206-14-hdı-trıger-ve-devırdaım-setı-orjınal,pr-5653.html
http://www.peugeotmarket.com/peugeot-206-14-hdı-alternator-rulmanlı-kayıs-setı,pr-2697.html
08.05.2020 20:08 # 5
Selox
600 TL is found
08.05.2020 20:08 # 6
hzr206
Thanks a lot, the comments were very useful. Since the financial situation is tight, I will change the v-belt, then I will try to show it to a master when I have the price of 90 TL from mobiloto.
[QUOTE = hasaydu bearings] Morning
Get well soon..
Your information.
Thank you for the suggestion. Brother, all the masters in the industry I took in Istanbul have attracted price like crazy.
