Timing Change and Traction
08.05.2020 16:54 # 1
tellotello
Hello Friends, Last Friday, I changed the timing set of my vehicle, the circulation pump, the tensioner belt and a ball that I could not remember in that part. It also changed because it was seen in my review that the turbo hose started to tear. In addition, the front brake was changed in the disc and pads. I made the procedures in Vatan Peugoet in Ankara. Thanks, they were very interested, and they also did not wear or trade without consent from me without deciding that all products were original. Each piece was shown to me one by one and then attached. It was observed that the circulation started in the circulation pump even if it was small. I have photos of the pieces that come out and I want to upload and receive your information when I have time. The only point we disagreed with was the antifreeze part with the master. And that is; When the measurement was made, an antifreeze was below 10 percent. I said let's put antifreeze in the discharged water of the vehicle and while refilling. The master told me that it would not be necessary to write, but I objected and I said that there should be some antifreeze in the vehicle, whether it be summer or winter. I hope I did it well. For this reason, we put 3 liters of antifreeze while putting water back into the vehicle and took the air off and started the system. I already suspected that the water in the expansion vessel was less than the color (it was transparent like normal water). Anyway now it looks green. Now let's come to the troubled side of the job. I took the vehicle out of service, I came home without any problems, but we are sitting somewhere on the slope and where I normally get out of 2nd gear, the vehicle collapsed and forced. I took it back to the same road and tried again. According to the old, there is low traction. There is no such great fall but it bored me the truth. There is no fault light or something and the vehicle appears to be OK. Are there any friends who have experienced this? I asked to consult you without taking it to the service. Thanks...
08.05.2020 16:54 # 2
sercinho
First of all, I don't think I have trouble. I can say that I could have jumped to the sentence but homeland peugeot & nbsp; a place that makes the heat better, the new apricot & nbsp; According to the more tense, it may have felt like it & nbsp; nakadara cost transactions i hope there is no problem.
08.05.2020 16:54 # 3
tellotello
Thank you,
& nbsp; I don't have any trouble about the place, I already called and said if we wanted to connect it to the computer and they said that the parts they replaced are not parts that will affect the traction. & Nbsp;
& nbsp; & nbsp; It took 800 in total, it sounded like a bit expensive, but I wanted it to be a reliable place, reliable material. Meanwhile, air and pollen filters were changed, and steering oil was reduced and completed. Let me write all of the changed parts, the bill would be on the vehicle. & Nbsp;
08.05.2020 16:54 # 4
You are 100% right about antifreeze and fortunately you insisted on it. What was the condition of the blades of the circulation pump? If it melts you can ask the master why it melted. Let's see what he will answer. Could your problem be caused by turbo? If I was at your place, I would get it back and have it checked.
08.05.2020 16:54 # 5
sercinho
I will be glad if you write the invoice in detail because I will change it because it can be from the turbo & nbsp; kolıva as the friend says
08.05.2020 16:54 # 6
tellotello
Hello
Reviews
& nbsp; & nbsp; It seems to me that there are no problems with the wings of the pump, but I don't know what it should be. I would appreciate if you inform me again when you see the photos.
& nbsp; & nbsp; Does the malfunction light on turbo-related problems? I ask him if there is no fault light on me. In addition, the turbo hose was the only thing to be changed, it had never occurred to me since it did not cause any trouble before. Let's take a look then. & Nbsp;
& nbsp; & Nbsp; The only problem is that I don't plan to go out of town tomorrow & nbsp; "C & nbsp; Napsamki, if I am not in this situation yet Is it okay?
& nbsp; & nbsp; Thanks for your interest.
& nbsp; & Nbsp; & nbsp;
08.05.2020 16:54 # 7
[QUOTE = tellotello] Hello
Reviews
& nbsp; & nbsp; & nbsp;
It's not over yet. Want to go now?
08.05.2020 16:54 # 8
turbo27
In some turbo failures, the lamp may not light up, the drain valve may be open, the flow meter may be defective, it may be tiny, there are many reasons ... take it to your master immediately.
08.05.2020 16:54 # 9
tellotello
Yes, I am from service right now. The turbo air flow filter is out of order, so they said it has fallen out of traction, and they changed it, of course, it was 220 lira & nbsp; "C & nbsp; Anyway, we got it done without going long. It appeared when I connected the car to the computer, but the malfunction lamp was not lit in any way. Many thanks for the help, guys. The construction doesn't cost me any more.
08.05.2020 16:54 # 10
uikaratas
[QUOTE = tellotello] Yes, I am from service right now. The turbo air flow filter is out of order, so they said it has fallen out of traction, and they changed it, of course, it was 220 lira & nbsp; "C & nbsp; Anyway, we got it done without going long. It appeared when I connected the car to the computer, but the malfunction lamp was not lit in any way. Many thanks for the help, guys. Construction doesn't cost me anything more. & Nbsp; [/ QUOTE]
What was the turbo flow filter? No flowmeters. Is there any picture of the piece or something?
When it was connected to the computer, it turned out that the malfunction came out, so it was understood?
Has the traction problem improved when I changed this part, so obviously?
uikaratas 2012-07-16 23:27:35
08.05.2020 16:54 # 11
tellotello
Hello
Reviews
& nbsp; I couldn't answer because I was out of town. I think they say in flowmeters or flow meters, I don't know exactly. It connects to the turbo hose, a cylinder-shaped piece located on the other end of the hose. No malfunction lamp was lit or warning, but the car was seen with the PP2000, it was seen that it had errors and it was said that the part should be replaced. I wish I would take your picture. Traction has improved after part replacement, it looks like there are no problems at the moment. I hope there is a dead end problem that has cost me a lot nowadays. & Nbsp;
