Timing change
08.05.2020 20:19 # 1
mhmtclb
Hello guys. My car Peugeot 307 XT Premium is now at 148,000 km. The timing set changed in 2009 at 90,000 km. Have you completed your life, how much do you think if I change it?
08.05.2020 20:19 # 2
I advise you to change it as soon as possible. If the oil is ok for maintenance, it will be around 500-600 TL. definitely replace the circulation pump. If the supplier industry is available, it will be more suitable.
08.05.2020 20:19 # 3
akyuz.cagri
I changed it today, friends. 14. hdi ... timing set, circulation, workmanship all 600 ..... sakarya ..
08.05.2020 20:19 # 4
keqir
Is it clear by looking at the control that this triger should change, or is there a change if it has necessarily come a certain km?
08.05.2020 20:19 # 5
maximusti
it is generally recommended to replace it between 80,000 -100,000 km.
When it exceeds 100.000, it becomes risky.
08.05.2020 20:19 # 6
x571
[QUOTE = maximusti] is generally recommended to change between 80,000 -100,000 km.
says 120-180 thousand in the service. Who will we believe? they will change every 50 thousand if they stay in the industry.
08.05.2020 20:19 # 7
180000 km service book writer teacher for 10 years, but Considering the difficult conditions of use turkey as 5 years under normal usage conditions apply 120000 km.
08.05.2020 20:19 # 8
maximusti
[QUOTE = x571] [QUOTE = maximusti] is generally recommended to change between 80,000 -100,000 km.
Unfortunately, if 10 people are asked, 7 is a question that comes with 8 different answers .. Let's say whichever your heart looks warm. My vehicle has completed 5 years but said 37,000 km, the service should change. My master does not need to see at least 80.000 said according to the situation. I do the same person for regular maintenance, 90,000 days, the first job is to change even if it says no need ..
08.05.2020 20:19 # 9
keqir
Today, they gave 750TL price for timing change in a private service. If I bought the set myself, I wouldn't eat a pile what I mean for workmanship. Big smile
08.05.2020 20:19 # 10
According to the master, they want between 200-300 TL, teacher. I do not give workmanship over 200 TL. Obviously it is easy to put on.
The original parts of the teacher are around 270 TL, the circulation + tiriger set, that is, max 500 TL. you can even change your oil and filters.
08.05.2020 20:19 # 11
keqir
thanks for your answer, my prediction was to be max.500.e, when i say 750 i was a little scared :)
I don't know when the old owner changed it, this job is on the top of my list right now
08.05.2020 20:19 # 12
talip206
I changed it to 350 in Ankara. The master looked at the circulation and said well. If he was bad he would take 100 more
08.05.2020 20:19 # 13
[QUOTE = talip206] I changed it to 350 in Ankara. The master looked at the circulation and said well. It would take 100 more if it was bad [/ QUOTE]
I am on the side of the circulation change, if the room is broken after two days, we have to give labor again.
08.05.2020 20:19 # 14
talip206
[QUOTE = sonerkyl] [QUOTE = talip206] I changed it to 350 in Ankara. The master looked at the circulation and said well. It would take 100 more if it was bad [/ QUOTE]
You are right hodja about that
But I did not know the history of the triger. When we removed it, we looked good belt. The master insisted on the circulation and insisted that there was no need. Or I had an intention.
08.05.2020 20:19 # 15
kilic46
Friends timing change is very important. 140 thousand Corsa diesel in the back. Today, the timing chain is broken. It is necessary to change it before it arrives. Then we stick to the conscience of the master. 3 or 4 or 4 or 5.
Masters do not want to change in time. When they have oily bread, they don't want dry bread.
08.05.2020 20:19 # 16
maximusti
[QUOTE = kilic46] Friends timing change is very important. There are 140 thousand Corsa diesel. Today, the timing chain is broken. It is necessary to change it before it arrives. Then we stick to the conscience of the master. 3 or 4 or 4 or 5.
Masters do not want to change in time. They don't want dry bread with oily bread. [/ QUOTE]
I agree with my nurse .. You are really at the mercy of the master when the time passes, and it usually results in bad results.
[QUOTE = keqir] Thanks for your answer, my prediction was that it could be max.500.e, I was a little scared when I said 750 :)
By the way, what did you do with the vehicle?
08.05.2020 20:19 # 17
keqir
I made the timing change, I gave 600TL including the whole set, pump etc. If you want service advice from Beylikdüzü, I recommend the place I have built.
