timing
08.05.2020 19:59 # 1
xt67
Hello friends;
My vehicle is 206 with xt brnzin 2005!
It has been like 2 years since I bought my car, only the person I bought does not know when the timing has changed. According to the paper we have, 90 thousand or so has changed as a set.
I know it is incomprehensible without disassembling, but it will be understandable when it is time to make any sound! ??
Thanks
08.05.2020 19:59 # 2
dejawu1978
When you look at the timing belt, you can understand that if there is no deformed belt, I think there is no problem ...
08.05.2020 19:59 # 3
When you go to the industry, if you tell the master, he only looks at it when a plastic cover is removed, it looks at the situation, cracking the belt, etc. if any, it is changed accordingly. You should feel comfortable waiting for the sound.
08.05.2020 19:59 # 4
xt67
Thank you, I will go to a master tomorrow
08.05.2020 19:59 # 5
ardinal
Timing change time for 206 1.4 hdi under difficult conditions is 180 thousand km / 10 years. I entered the chassis and looked at the servicebox. (It is not any authorized service that says this, it is direct peugeot)
If it has never changed, there are 180 thousand ways already :) I do not know my vehicle before but I will change when I approach 180 thousand just in case. You can enter the vehicle's chassis number in the servicebox and get information.
 http: //public.servicebox. I peugeot.co
Make the language Turkish in the lower left corner of the page. then sign up for the site.
After logging in, in the upper left corner, the box asking for VIN / VIS information
Enter the chassis number and start tampering :)
Ardinal 2016-10-04 15:29:12
08.05.2020 19:59 # 6
xt67
Thank you very much bro
I wrote 140 thousand because km is not 131000
Maintenance plan 1: says revisions and pollen filter replacement
Additional operations 5: rear brake drums
Brake fluid
Air filter
Timing belt
Combustion spark plugs
It turns out it is a little confused
08.05.2020 19:59 # 7
madblueblacksea
[QUOTE = ardinal] Timing change time for 206 1.4 hdi under difficult conditions 180 thousand km / 10 years. I entered the chassis and looked at the servicebox. (It is not any authorized service that says this, it is direct peugeot)
If it has never changed, there are 180 thousand ways already :) I do not know my vehicle before but when I get close to 180 thousand, I will change just in case. You can enter the vehicle's chassis number in the servicebox and get information.
 http: //public.servicebox.  peugeot.co
What is the timing change 180 thousand?
08.05.2020 19:59 # 8
ardinal
first timing belt change is 180 thousand. the second one is 360 thousand. is progressing in this period. but 140,160 thousand etc. The word "changeable" is displayed as an option. let me upload a picture :)
08.05.2020 19:59 # 9
ardinal
I have put up to 180 thousand maintenance plans and additional operations. the timing seems to be an additional process even at 20 thousand km. my comment says that if you want peugeot you can change it additionally. When we reach 180 thousand km, it goes out of the process and goes into the maintenance plan. The meaning I got out of here should definitely be changed in 180 thousand.
vehicle age 8, hard conditions, 1.4 HDI, this is what I wrote for. everyone can have a different outcome for their car and its age. I have a km or year life for the timing, I said from it :)
20 thousand maintenance
20 thousand additional
40 thousand maintenance
40 thousand extra
60 thousand maintenance
60 thousand additional
80 thousand additional
100 thousand maintenance
100 thousand additional
120 thousand maintenance
120k additional
140 thousand maintenance
140 thousand additional
160 thousand maintenance
160 thousand additional
180 thousand additional
Ardinal 2016-10-05 11:34:29
08.05.2020 19:59 # 10
ardinal
[QUOTE = xt67] Brother thank you very much
Brake fluid
Air filter
Timing belt
It turns out it's a little bit confused .. [/ QUOTE]
How many thousand km is shown in the maintenance plan? try them all one by one.
Look at the additional operations for each km, you have to change the timing every 20 thousand km.
look carefully at the last 2 pictures I shared, the timing is not in the addition process, in the maintenance plan :)
If there is always a doubt in it, change it and you will be comfortable: D
Ardinal 2016-10-05 11:46:03
08.05.2020 19:59 # 11
ALLEX
Sir, change the timing with the circulation, I think.
In case of malfunction, it can cost a lot of money.
My car 2004 model 1.4 hdi
The mileage is 390 000 but now it sounds like a shit to me.
My head is comfortable. I have also renewed the new one.
08.05.2020 19:59 # 12
xt67
They said there was no problem in the timing, but the vehicle vibrates slightly when the vehicle is stopped. I think I'll have him look at it tomorrow!
08.05.2020 19:59 # 13
senalcay
I have the same vehicle, friend. The timing change in our vehicle is 80.000 km. no less than 2000 TL expense, no risk.
senalcay 2016-10-05 18:27:13
08.05.2020 19:59 # 14
ardinal
[QUOTE = ALLEX] Sir, I change the timing with the circulation.
My head is comfortable. I have also renewed the new one. The comfort of the outdoor condition is like new.
May Allah grant 390 thousand more insallah :)
Have you changed the bearings with the alternator belt? There is a bidet alternator box. Do you need bearings and boxes? It seems to me that belt + bearing make sense. Kutuk expensive puppy: D
08.05.2020 19:59 # 15
madblueblacksea
Triger wrote 80 thousand changes, not 180
08.05.2020 19:59 # 16
Ahmetaltan
My car 2006 1.4 hdi. At 14,500 km. When I bought my car 1, 5 years ago, the owner before me did not know when the triger had changed. I asked this to the mechanic. The room showed me the condition of the bearing that a Peugeot partner before me changed on the set of the timing. The belt was in good condition, but the bearing was making noise. He told me (the timing belt is replaced when it is not checked. Timing belt is unlike alternator belt, whether it has a crack or not. It probably breaks until it comes to that state).
08.05.2020 19:59 # 17
madblueblacksea
[QUOTE = Ahmetaltan] My car 2006 1.4 hdi .145000 km de.When I bought my car 1, 5 years ago, the owner before me did not know when the triger had changed. I asked this to the mechanic. The room showed me the condition of the bearing that a Peugeot partner before me changed on the set of the timing. The belt was in good condition, but the bearing was making noise. He told me (the timing belt is replaced when it is not checked. Timing belt is unlike alternator belt, whether it has a crack or not. It probably breaks until it comes to that state). [/ QUOTE]
+9
08.05.2020 19:59 # 18
hasayduman
Hello there,
Brother, when I bought the car last year, the person I bought had no information about the treger set changed or changed, I changed the car to 130 TL at 130,000 km, I am comfortable riding,
While escaping from 300, you should not leave 2,000
08.05.2020 19:59 # 19
xt67
Sister hello 300 TL, I just changed the timing, I guess the circulation faln needs to change, they say it costs 700-800 workmanship or something
08.05.2020 19:59 # 20
No, if you add 700-800 TL into the maintenance, my teacher, I will tell you
1-timing set between 100-150 tl
2-rolled around 70-100 tl
3-v belt between 20-30 TL (the price of the billet must be 100-odd excluding the billet)
4-oil 4 liters 60-80 TL according to the brand
5-oil filter 20 tl - air 20 tl - pollen 20 tl - fuel filter 20- diesel should be around 80
6-drink between 200-300 TL
If you give 300 TL in workmanship, you will make 740, I wrote high prices, these prices may increase or decrease according to the part you receive.
Page : / 2
