tie rod balance
08.05.2020 14:51 # 1
Ego_Ist
Hello friends,
After 100 km speed in my car, there is a slight tremor at the steering wheel, if I make a rot balance setting, the problem will be fixed, I asked the tire dealer I bought 50 TL,
are there people who made this setting before ??? Is there a noticeable change in the vehicle's departure ???
thanks..
08.05.2020 14:51 # 2
muhlisoz
yes, if you are too late to get it done, the tires will die because of the rot balance, I saw a pert tire with a few months old wires. bi rot balance adjustment should not be so expensive, ask about 20 lira last year
08.05.2020 14:51 # 3
H-a-d-i
Bridgestone, where we bought 2 tires last year, made this adjustment for free. It does not exceed 25-30 TL.
08.05.2020 14:51 # 4
okankrgz
[QUOTE = Come on] Bridgestone, where we bought 2 tires last year, made this adjustment for free. It does not exceed 25-30 TL outside. [/ QUOTE]
+++ Alkış
08.05.2020 14:51 # 5
Aytac
There Is A Levent Master In Akınsal Sanai Site.
08.05.2020 14:51 # 6
haruncoskun
when they bought the tires they had to change the free valves and adjust their balance
08.05.2020 14:51 # 7
turbo27
There are 40 people who want to balance the balance of the rods. There is no more than 20 or 50 people who want to do it. If you have a shake after 100, you can only get the balance adjustment. make the balance adjustment ... they will see the wheels already. When the balance is done, adjust them if they are ... they adjust the rim fixing price for 20 lira individually.
08.05.2020 14:51 # 8
kitay
I made the rod balance adjustment for the long road, when I passed the 100 km speed, there was a tremor in the steering wheel, they said 60 TL in the maslak industry, 50 tly I understood that my front tires were worn out, they replaced the rear tires with the left tires, I was very satisfied, there was 170 km speed, there was neither trembling or right pulling. I hope your problem disappears after you make adjustments
08.05.2020 14:51 # 9
turbo27
yes, if the tires of the front wheel drive are made on the rear every 15000 km, the tires are set at least 100,000 km if the air adjustment is used properly and the tie rod balance adjustment is correct.
08.05.2020 14:51 # 10
If there is a misalignment in the balance or the curvature of the cant makes the steering wheel vibrate.
08.05.2020 14:51 # 11
Ego_Ist
thank you for the advice guys
08.05.2020 14:51 # 12
karaca rot balans
USTAM MRB .. I AM MASTER IN EYÜP KARACA ROT BALANCE SERVICE
I READ YOUR COMPLAINT. YOUR COMPLAINTS ARE SOURCE FROM THE BALANCE SETTING IF THE BALANCE IS DONE, AFTER THE COMPLAINT IS DONE, I HAVE TAKEN THE BEST BALANCE ... WHEN THE TIRES ARE INSTALLED NEW, THE BALANCES ARE MADE UP, THE CUSTOMER IS CALLED 500 KM OR KM AFTER YOU COME A BALANCE CONTROL. THERE LIKE A SHOE, IT WILL LIKE AFTER A STRONG TIME. BUT REQUESTING MONEY TUAF .. WE DO NOT MAKE A PROBLEM ON OUR CLIENT TO OUR CUSTOMER, WE MAKE 20 TL IN NORMAL BALANCE TO YOUR INFORMATION ... HAPPY IF I HELP YOU. IF IT CONTINUES YOUR COMPLAINT, LET'S COME TO OUR SHOP, WE CAN HELP YOU ..
08.05.2020 14:51 # 13
xMEGANx
What if you said 50 or brother, you are passing the wave, choosing the man? 15 TL in Istanbul / Beylikdüzü / Carrefoursa lassa Dealer. 15 TL. ne 50 si 50 tl bn the vehicle's tank is halfway
08.05.2020 14:51 # 14
xMEGANx
Who is balancing rot for 200 TL for God's sake? Where is 15 TL and 200 TL? exaggerate a little more carefully when exaggerating
08.05.2020 14:51 # 15
GokhaN
it is just the balance you call 15 TL. rot is made after balancing.
08.05.2020 14:51 # 16
erdal
Just like 15 TL balance setting only :) After installing winter tires, the balance setting went off after 130, the steering wheel began to shake when I passed it .. last week I did it. ..
08.05.2020 14:51 # 17
We made our 307's tires back-front. He began to tremble extremely in 120. It has been balanced at least 4 times, the old type has been balanced, it has not improved in any way. There was no problem with the tires. Balancers were also surprised.
08.05.2020 14:51 # 18
I made the tie rod balance for 15 TL and at the authorized service
08.05.2020 14:51 # 19
xMEGANx
[QUOTE = LANOPE] I made the rod balance 15 TL and also at the authorized service [/ QUOTE]
+1 Alkış
08.05.2020 14:51 # 20
206_arda_gti
[QUOTE = Ego_Ist] slm friends,
thanks..
My car's back 2 tires were broken, I could have a tie rod, but I couldn't balance it. I have been using my car for about 2 months, it is unbalanced and really very, very risky situation. When I passed 130, 140, the car was about 4-5 cm left and right. I changed the tires and got a free balance, and the first word I said was to the world. 140-150-160 =) there is no single skid. Also, if you bought a tire, they make the balance adjustment free of charge.
the 206_arda_gt 2010-12-28 01:18:03
