Throttle up at 206 gearshifts
08.05.2020 20:38 # 1
okaNStarss
Mrb friends have done research in the forum, but this has always been a problem due to the throat butterfly in gasoline vehicles, but my car has done several times while the air conditioner is running in the summer. Now, with a little red gas, my car continues to deliver gas at gear shifts. There's nothing wrong with idle. While deserving, the gas continues for 2-3 seconds, which will go from 1 to 2 to 2 to 3 4. When the vehicle stops and waits for 20 seconds and runs, everything gets better again. Is there any problem or solution?
08.05.2020 20:38 # 2
Did my teacher have a fault code, as if the flow meter was defective?
08.05.2020 20:38 # 3
okaNStarss
I did not receive a warning on my screen to not give error or fault code
08.05.2020 20:38 # 4
KILIC
Is your gas pedal electric. It may be related to the accelerator pedal sensor.
08.05.2020 20:38 # 5
okaNStarss
yes electronic, but the vehicle does not relay. the accelerator pedal does not have any fluctuations and seizures
08.05.2020 20:38 # 6
KILIC
Well, first of all, I do not get stuck in the gas pedal mat.
08.05.2020 20:38 # 7
onlycihan
The biggest factor is that it doesn't come to mind or understand either at that moment, either fix your mat well or try it for a while without using it. because every time we land on the vehicle, our foot pushes the mat to the bottom of the pedal
08.05.2020 20:38 # 8
Popomundo
As the friends say, either the mop or fuel system is getting air from somewhere, or the device malfunctions ...
08.05.2020 20:38 # 9
okaNStarss
I shortened the mop to see if it was a mop, but I often shoot when I do it. the trouble is, for example, you took off at a high speed in the light, you took the serial, when it stops again, it gives its own gas at the gear changes problem.
08.05.2020 20:38 # 10
Baris61
The same problem exists in my vehicle. You can search the internet on the clutch sensor.
12.05.2020 06:15 # 11
canr26
I wonder if your problem is solved, I have the same problem in my car
12.05.2020 09:30 # 12
ismailkaya
It could be your style of use. The vehicle operates differently when the air conditioner is on.
17.05.2020 04:35 # 13
canr26
No, I tried it one day, I used it very cyclically, I used it calm one day, after about an hour, I encountered the same problem.
17.05.2020 14:33 # 14
okaNStarss
The subject is ghoulish, I still can't get on that way.
17.05.2020 21:19 # 15
ismailkaya
Use normal for a week
18.05.2020 00:29 # 16
canr26
It hurts my hurt, sometimes when I press it lightly, I throw the gear around 4 thousand cycles, the car goes crazy, I come to the redline, I feel like it will explode the engine, when I do this, I throw it out, I give gas very late, it knocks, the car stops, I give gas everything goes back to normal, I go into gear again, the gas returns to the old state continues
06.07.2020 13:21 # 17
okaNStarss
I have changed all the km sensor and the pressure lining equipment, I have not received an error, it has been a long time.
06.07.2020 15:35 # 18
kaan206
Electronic throttle problem
30.07.2020 03:54 # 19
canr26
I have solved the problem, there is a part called the clutch switch, it is attached to the clutch pedal, they removed it, the problem was solved by the reverse team, the reaction of the car changed or something, and there was no problem left in the car.
