Throttle problem
08.05.2020 21:18 # 1
Mvl
Hello there! My 307 gasoline vehicle did not eat gas when I started it several times, but it was improved when I opened and closed the ignition twice. I went to the industry. Throttle error on the computer. CLEANED MASTER then put on the car did not eat the same gas, he said buy a new one. He put the new one on the same (we bought a brand of bosh 600 rubles). They haven't found a solution in industry for 3 days. He said, "I would try to knock one off or the exhaust was blocked. Let's try it tomorrow." If anyone knows about it, I would be happy if it helps
08.05.2020 21:18 # 2
ismailkaya
Mvl You couldn't explain your exact problem.
Is the engine version of the vehicle 1.4 -.1.6 - 2.0 gasoline? Is it diesel? Lpg li?
When did you start your car for the first time?
When the vehicle starts for the first time, it does not eat gas and does the vehicle accelerate hardly?
Is there any improvement afterwards?
Is the air filter new?
Do you feel an abnormality while the engine is running?
08.05.2020 21:18 # 3
Mvl
Tool 1.6. Gasoline LPG does not eat gas even at the first operation of 185 thousand. It stays idle, the computer calls the throttle fault. Even when the mistake was erased, the same master said that there is a problem in the brain, and I left it to the master, and the car was still not resolved.
08.05.2020 21:18 # 4
KILIC
Hodja shut down the LPG from the tank and try it in a few days.
08.05.2020 21:18 # 5
ismailkaya
electrical cables, fuses, if the throttle does not react. Have lpg electrical wiring and catalyst sensors checked. failure to react may result from these.
08.05.2020 21:18 # 6
ugur9tezcan
Hello. I had the same problem, even I was on the road. The vehicle does not eat gas, remains idle, but goes off when I put it in 1st gear and take off Shocked Even if I took my foot off the gas like an automatic vehicle, it was going at a speed of 10 km. On the way, I found a mechanic, saw the motorized butterfly error from the tablet and the throttle had just changed 2 weeks ago. The master cleared the error and had no problems. 1.6 gasoline + atiker lpg in my car
