throttle lining spray
08.05.2020 21:19 # 1
Dogukan_3002
If our vehicle's crank sensor is defective, can it be operated by spraying the lining on the throttle Dogukan_3002 2019-09-08 08:27:16
08.05.2020 21:19 # 2
talip206
If the crank sensor is faulty, it will not work that way. You have to move the car in gear so that the crank sensor can detect motion. Of course, there is no such thing as working for sure, but it usually works.
08.05.2020 21:19 # 3
ismailkaya
If the crank sensor is defective, I think it will not work, even the starter will not work, but all electrical functions will work, but I know that the starter will not start.
08.05.2020 21:19 # 4
Dogukan_3002
[QUOTE = talip206] If the crank sensor is faulty, it will not work that way. You have to move the car in gear so that the crank sensor can detect motion. Of course, there is no such thing as working, but it usually works. [/ QUOTE]
I suspected the crank sensor. yesterday I left it in gear and moved it back and forth 5 cm, is that what you mentioned or is it hit? by the way did not work :)
08.05.2020 21:19 # 5
Dogukan_3002
[QUOTE = ismailkaya] If the crank sensor is faulty, I think it will not work even if the starter does not work, all electrical functions will work, but I know that the starter will not start, when the starter does not start, the pad will not work, and the pad will not tighten everywhere, especially the belts and rubber gaskets will not rot the tire immediately. [/ QUOTE]
I suspected the crank. the vehicle warms up to two months ago and sometimes stops while on the road. I continued and started again without stopping immediately, but after going 300 meters in this way, I never worked. I parked by pushing from where I left in the morning. of course it was working because it was cold. but it went completely 10 days ago. As always, I came and parked. I arrived 4 days later.
Dogukan_3002 2019-09-08 11:32:14
08.05.2020 21:19 # 6
ersin61
I've had the crank sensor malfunction. The breakdown is intermittent, the vehicle sometimes stops as if it is singing. There are problems like too late to work as it progresses. The crankshaft stop circuit information allows the injectors to distribute the fuel through the brain. I know briefly. When you connect to the computer, the problem occurs.
08.05.2020 21:19 # 7
Dogukan_3002
[QUOTE = ersin61] I had the crank sensor malfunction. The malfunction is intermittent at the beginning, sometimes it stops as if the vehicle is stalling. There are problems such as not working as it runs too late. The crankset burner provides the injectors to distribute the fuel through the brain. There are problems such as kicking or not working, such as stopping.
I wonder if I can't remove this crank sensor? I thought I would clean it and wear it.
08.05.2020 21:19 # 8
ersin61
It is necessary to try and sometimes it is necessary to disassemble the crank pulley as it is on the belts ..
08.05.2020 21:19 # 9
ismailkaya
By the way, you never mentioned what is the brand model fuel of your vehicle
08.05.2020 21:19 # 10
talip206
The location of the crank sensor 206 is also easy. It holds one screw. What is your vehicle model. Crank sensor malfunction usually happens when the engine is hot. When the vehicle is in gear, try moving it 1 2 meters. Crank sensor starts when there is malfunction, but the car does not start. Because it cannot adjust the firing time. talip206 2019-09-08 20:30:14
08.05.2020 21:19 # 11
Dogukan_3002
[QUOTE = talip206] The location of the crank sensor is also in 206 easy place. It holds one screw. What is your vehicle model. Crank sensor malfunction usually happens when the engine is hot. When the vehicle is in gear, try moving it 1 2 meters. Crank sensor starts when there is malfunction, but the car does not start. Because it cannot adjust the firing time. [/ QUOTE]
206 plus so the plus one in me. no lpg was installed. I removed the map sensor and attached it to the screw. So what would be better, let me get it out right away. If I don't find out tomorrow, I will take a picture. yes, when the engine was hot. When I say put it in gear and push it, I will put it in 5th gear and not push it. experience right now .. yes it never works anymore. gradually months later it came to this situation and it is now over.
Dogukan_3002 2019-09-08 20:50:32
08.05.2020 21:19 # 12
talip206
I think it's the same as normal 206. Let me describe its location as follows: between the radiator and the engine blog and down about 50cm. You'll see your socket already. An L-shaped piece, usually gray or black. It's hard to see because it's below.
talip206 2019-09-08 22:06:49
08.05.2020 21:19 # 13
Dogukan_3002
[QUOTE = talip206] I think it's the same as normal 206. Let me describe its location as follows: between the radiator and the engine blog and down about 50cm. You'll see your socket already. An L-shaped piece, usually gray or black. It's hard to see because it's below.
I could not shoot videos, my hands were very dirty, but I would follow the subject and share the sample video I watched for this problem that might happen [TUBE] iY5naxhO4n4 [/ TUBE]
Dogukan_3002 2019-09-12 18:15:14
08.05.2020 21:19 # 14
Dogukan_3002
[QUOTE = Dogukan_3002] [QUOTE = talip206] I think it's the same as normal 206. Let me describe its location as follows: between the radiator and the engine blog and down about 50cm. You'll see your socket already. An L-shaped piece, usually gray or black. It's hard to see because it's below.
He took care of LOL
I'm showing you here (right next to the hose)
look who I found Tongue
veee finalll LOL
Dogukan_3002 2019-09-12 18:18:08
08.05.2020 21:19 # 15
talip206
Did the problem come out of the crank sensor? He was in the same place as the 206. Only when the radiator is hot, its replacement is burning badly.
I also dropped the screw back side by side. I had been doing a lot of stress because the crank sensor fell into the Transmission through the gap inside it Big smile
talip206 2019-09-12 21:54:59
08.05.2020 21:19 # 16
Dogukan_3002
[QUOTE = talip206] Did the problem come out of the crank sensor. He was in the same place as the 206. Only when the radiator is hot, its replacement is burning badly.
As I removed the crank sensor, I immediately looked at it .. the sensor part was covered with black oil like slime or something. I took it out and put it home. I thought I would buy the oil-free electronic circuit spray and wipe it clean (as the brake pad will damage the spray). I don't know how to hold my breath and resist that tension feeling. such as not being able to look at the screen when using a penalty LOL It was like ice because it hasn't been working for me. Since only one arm entered the radiator part, I completely removed the air filte box to the throat butterfly part. (I also clean the butterfly) I was able to insert my hand and open the screw more comfortably ... so I should be very careful when installing and removing the screw. Smile the most feared part of me was this screw Big smile
Dogukan_3002 2019-09-13 00:23:20
08.05.2020 21:19 # 17
Dogukan_3002
and finally my car did not work in exchange for cleaning and fitting at the end LOL click here Smile
I think it's either dead or the problem is from something else.
