Throttle cleaning aid :(
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 16:48 # 1
volkan22
my friends good forums my 306 throttle is dirty and the idle problem starts to show bass it fell slightly at 1000 rpm ...
& nbsp; I put the manifport with the butterfly but I don't want to do a wrong application cleaning I will do it with the help of my experienced friends ...
2.0 16v & nbsp; machine & nbsp;
I am waiting for your urgent help with the illustrated explanation warsa, which is similar to the 1.8s' manifest now.
< / div>
08.05.2020 16:48 # 2
ufuk91
I made that mistake, do not do it, go 40-50 clear it, I cleaned it myself, even more than my old idling problem, the current idling problem, did not fix it even worse, you will understand, I will take it on Wednesday and give it whatever they want.
08.05.2020 16:48 # 3
volkan22
You broke the throttle, bro? Or did you clean the whole?
08.05.2020 16:48 # 4
ufuk91
[QUOTE = volkan22] Did you break the throttle, bro? [/ QUOTE]
no brothers after the disassembly adaptation or something, they said, I cleaned the front of the car with the lining spray on the vehicle without breaking it, I pulled the gas wire and cleaned the back as much as I could. but as I said, the idle has become imbalanced, usually started to work at 1300 rpm etc., more than old problems have occurred.
08.05.2020 16:48 # 5
falan
same nuisance & nbsp; had it in me & nbsp; I cleaned it, it did not improve, I changed the temperature sensor, it did not, I was able to provide the latest throttle with the idling engine or something like 220 TL.
08.05.2020 16:48 # 6
volkan22
Strangely, I have reinstalled all the parts of the car today, the tool is working fine, I put it up to the injections, I cleaned it with a throat butterfly, etc. I have installed it today.
