Throat Butterfly (Lpg Failure)
08.05.2020 16:12 # 1
yegane
Hello Friends,
I have 307 Atiker installed on my car, but since the car has been idling since the first day, there has been a steady increase in engine speed. Sometimes the vehicle even stops. The master butterfly throat that I have assembled the lpg said that the throat may be dirty and should be cleaned. Does anyone know why it might originate? Does this breakdown cost me dearly? Could you help.
08.05.2020 16:12 # 2
They clean the throttle for 20-30TL.
08.05.2020 16:12 # 3
mimitt
butterfly cleaning may solve the problem, but if the idling fluctuations do not improve after cleaning, the idling engine may need to be replaced. In bosch car services, the engine was a figure of 150 160 TL with the replacement fee.
08.05.2020 16:12 # 4
yegane
Is there a master you can recommend?
08.05.2020 16:12 # 5
mimitt
If you update your profile information, we will know where it is and we will try to help you with that.
08.05.2020 16:12 # 6
psychoabi
When I talked to the master who wore the LPG for a long time, I told him that he did what he did from the throat butterfly. It has improved, connected to the computer and changed its settings, but now the vehicle sometimes stops when it's cold
08.05.2020 16:12 # 7
metin
[QUOTE = unique] Are there any masters you can recommend? [/ QUOTE]
& nbsp;
unique;
You want missing master advice from your profile information. Now I do not know where you are, I do not know what vehicle you have, how can I give you expert advice or guide, right?
& nbsp;
we can not press it in vain, write your profile information completely, enter the information of your vehicle in the signature section.
08.05.2020 16:12 # 8
[QUOTE = text] [QUOTE = unique] Is there any master you can recommend? [/ QUOTE]
& nbsp;
unique;
you want missing master advice . Now I do not know where you are, I do not know what vehicle you have, how can I give you expert advice or guide, right?
& nbsp;
don't press it in vain, write your profile information completely, enter the information of your vehicle in the signature section.
& nbsp;
I strongly agree & nbsp; +1 "Thumbs
08.05.2020 16:12 # 9
Muhammet CAKIR
yesterday I removed the throat butterfly and cleaned it became a monster :)
08.05.2020 16:12 # 10
metin
[QUOTE = Muhammet ÇAKIR]
yesterday I removed the throat butterfly and became the monster car :)
& nbsp;
it's my turn, Saturday I hope I will do it too.
08.05.2020 16:12 # 11
34sea45
I am bored of cleaning the engine, I changed the engine from the root problem, I gave 170 TL including the installation 2 months ago
08.05.2020 16:12 # 12
[QUOTE = text] [QUOTE = Muhammet ÇAKIR]
yesterday I removed the throat butterfly and became a monster car :)
& nbsp;
it's my turn, I hope I'm going to do it on Saturday.
& nbsp;
Remembering my text is not your manual butterfly ... I can advise you to be a motorized butterfly and if you can, & nbsp; ugrasmman
08.05.2020 16:12 # 13
Muhammet CAKIR
[QUOTE = CeCoLi] [QUOTE = text] [QUOTE = Muhammet ÇAKIR]
& nbsp;
& nbsp;
[/ QUOTE] I do not have to worry if I clean the motorized plug socket without adaptation, there is no need for adaptation again. but if I do what I said it won't be a problem "Blink"
08.05.2020 16:12 # 14
tuncercoban
Hello Friends,
& nbsp;
K.Çekmece, where you can find the cleaning, adaptation, repair of the electronic part, removal or zero of the throat butterfly; Carburetor Mehmet Usta & nbsp; var. And it does this job very cheaply and guaranteed. If you need, you can call (05357191078) or E-Mail ( tuncercbn@gmail.com ) and send your problems you can get information;)
08.05.2020 16:12 # 15
muhammed.ceyhan
Was it possible that the rotation remained stuck at 2000 or 3000 or 4000 as well as idle fluctuation?
I have such a problem. Coz I did not. they wanted to change a butterfly. Let's see the idling engine will change first. if not, butterfly bogazi.
08.05.2020 16:12 # 16
muhammed.ceyhan
We also gave the subject a ghoul.
08.05.2020 16:12 # 17
Karacocuk24
I am always in between whether I switched to LPG or not, I stop when I hear such problems, do not I am afraid that there is no trouble, except just periodic maintenance, just put the gas and go :)
08.05.2020 16:12 # 18
badtemperad
Hodja today, I have that problem, not the gas setting, but the throat butterfly needs to be cleaned regularly. Tupte does no problem with gasoline, and many masters need to clean it, he said, I will give the car on Thursday. I do not know if the money is clean but it is necessary to adjust the gas when it is cleaned. I will share if I get information
08.05.2020 16:12 # 19
muhammed.ceyhan
butterfly was cleaned 2 times. I replaced the idle engine. It was largely resolved. I have been using it for two days. This evening made a few fluctuations. thank you also.
08.05.2020 16:12 # 20
selim38
If you haven't looked at the oxygen sensor, look at it.
Page : / 2
