Throat butterfly cleared does not eat gas
08.05.2020 21:19 # 1
lilokan
The throat butterfly of the car was cleaned and then I realized there was a problem with the traction. Bikac gun I got on and it was bad. The car is singing as if 2 eyes are not working. It seems like the gas is picking up until the end, but the car is not going and it is singing. Throat butterfly was after cleaning
I'm in a different city now, I can't go to the master. I wonder if it was a throat butterfly or could it be in your coil
08.05.2020 21:19 # 2
talip206
Coil can be. If the tachometer is playing too much, if the rpm drops too low and recovers hard, there may be an idling engine. Throat butterfly and idler motor may be damaged because they are in the same place. But it seemed more like a coil failure to me.
08.05.2020 21:19 # 3
lilokan
[QUOTE = talip206] Coil may be. If the tachometer is playing too much, if the rpm drops too low and recovers hard, there may be an idling engine. Throat butterfly and idler motor may be damaged because they are in the same place. But it sounded more like a coil failure. [/ QUOTE]
Sir, there is no problem in the cycle. It does not fluctuate at idle, but it does not eat gas. It feels like the bottom is recovering when it makes gas, but it still doesn't draw exactly
08.05.2020 21:19 # 4
lilokan
friends, my problem is solved. Thank God there was a break in the cables going to the coil and this was done without any cost. Thank you for your help
08.05.2020 21:19 # 5
talip206
Get well done without any cost.
08.05.2020 21:19 # 6
lilokan
[QUOTE = talip206] Get well done, you're done with no cost. [/ QUOTE]
Thank you, teacher again
08.05.2020 21:19 # 7
ismailkaya
How did you break the cable going to the coil or dismantle the vehicle by breaking it? ))) the air filter probably damaged the bottom of those cables
08.05.2020 21:19 # 8
lilokan
[QUOTE = ismailkaya] How did you break the cable to the coil or disassemble the master? ))) the air filter probably damaged the bottom of those cables [/ QUOTE]
I think hodja. We are suffering from a master problem on my subject.
