Throat butterfly cleaning
08.05.2020 18:43 # 1
yigit4516
We have 306 vehicles. While I was cleaning the air filter the other day, I rubbed my hand into the throat butterfly and the black oil came out. I took a cloth in my hand and cleaned it, but since I tried to clean it without removing it, I could not clean it completely. Some vehicles had to adapt after the throttle was cleaned. Is there such a thing in our 306? Because the idling speed has increased a bit after cleaning ..
I have a second question.
I do the minor maintenance myself. while the vehicle is working on gas, it eats the gas a little late and as a result of my long research I guess the problem is in the gas injectors. In a video I watched on Youtube, the man explained how to clean the injectors and I wanted to do it myself. It was not difficult. But of course, there are important points in this, I mean, I don't think if it will be worse than before after cleaning.
08.05.2020 18:43 # 2
Barut
If your vehicle has a accelerator pedal, no adaptation is required. Recently, I wiped the throat butterfly with a dry cloth and removed a little oil. In the past, there was a slight fluctuation in the cycle, now it has improved and its performance has increased visibly in the vehicle.
08.05.2020 18:43 # 3
yigit4516
yes there is a gas wire. Thanks..
08.05.2020 18:43 # 4
Ahmet_ach
Clean the throat butterfly and idler engine with thinner or lining spray.
Ahmet_ach 2014-07-20 18:10:35
08.05.2020 18:43 # 5
yigit4516
I cleaned the lpg injectors and throat butterfly today. I opened the air filter inlet without clearing the throat and cleaned the butterfly in that way. I don't think it's cleaned up, but it's still better than before. Lpg injectors are black from the dirt. After cleaning, it was to correct the drop in speed especially in the first gas or intermediate gases, but this did not help much. I think spark plugs haven't changed at least 35 thousand km at best. Also, after this cleaning, we did not make any filter change or adjustments. Considering these, it is normal for the distress to continue without increasing. However, both lpg injector cleaning and throat throttle cleaning increased the performance in both lpg and gasoline. I will be happy if I can prevent the cycle from decreasing at the first gasing time in this LPG.
08.05.2020 18:43 # 6
sezar206
How low is the cycle at the first gas release? If there is not an exaggerated situation, I think it is very tampering.
08.05.2020 18:43 # 7
serkans
Is there a throat butterfly in diesel vehicles my vehicle 207 1,4 2010 mdl
08.05.2020 18:43 # 8
yigit4516
[QUOTE = fatihpekgoz] How much does the cycle decrease in the first gas release? If there is no exaggerated situation, I think it is too much tampering.
For example, when the vehicle is idling, I press the throttle at medium intensity, it drops from 900 to 700-750 and rises again. At that moment, the motor was shaking. The same thing happens when I suddenly press the gas while looking at you. He can't get the first gas reaction right away ... This situation gets angry, though. I want to get the gas response right away.
08.05.2020 18:43 # 9
popeyes
After clearing the throat butterfly, put it in place nicely, after that, you make the contact 10 times on and off.
[QUOTE = valiant4516] We have 306 vehicles. While I was cleaning the air filter the other day, I rubbed my hand into the throat butterfly and the black oil came out. I took a cloth in my hand and cleaned it, but since I tried to clean it without removing it, I could not clean it completely. Some vehicles had to adapt after the throttle was cleaned. Is there such a thing in our 306? Because the idling speed has increased a bit after cleaning ..
08.05.2020 18:43 # 10
lead38
I cleaned the throat butterfly, the malfunction lamp burned
08.05.2020 18:43 # 11
sezar206
[QUOTE = yiğit4516] [QUOTE = fatihpekgoz] How much does the cycle decrease in the first gas supply? If there is no exaggerated situation, I think it is too much tampering.
Man, in the coil of your question, then with great chance.
08.05.2020 18:43 # 12
suppor
I did not solve this throat butterfly conversation.
08.05.2020 18:43 # 13
lead38
It is not a fuel pump in diesel vehicles.
08.05.2020 18:43 # 14
serkans
thanks for my friend cvb
