THP not consuming gas, burning raw fuel, rich mixture mistake
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 508
06.08.2023 23:00 # 1
Huseyin dokme 508
P.S. friends I have a 2011 508 thp access package manual car with 110 thousand kms of service maintenance. After getting fuel from a different place, the problem of not getting gas in the car started. When connected to the computer, it started giving p0087 p0171 p1336 37 38 39 errors. Thereupon I took it to the authorized service. They said that there might be a problem with the catalytic converter, high pressure pump and float switch. They said that the vehicle was burning raw fuel and that it was an engine malfunction and that they should not repair it but replace the engine. They said we would see whether the catalyst and float switch should be changed after replacing the engine. The spark plug, coil, fuel filter, zero high pressure pump, catalyst were installed but the same problem still persists. Is there anyone who can help me solve this problem of not getting gas?
