Those with belt problems!
08.05.2020 18:53 # 1
candanxyz
If the alternator (V) belt makes no noise, the bearings are not a problem in the pulley and the slab, and if you still wear the original belt, I will suggest you a belt.
CONTİTECH (CONTİNENTAL)
The structure of this belt is many times better than the belts you wear as original.
It may even be called the best strap in the world.
Mercedes And BMW use this strap as oem.
Even when you put it side by side with the original strap, you can easily understand the difference.
It is recommended for all models, not just 206.
candanxyz 2014-11-17 16:19:24
