Those who understand from 307 should solve this problem.
08.05.2020 19:15 # 1
samet2461
Friends, I am writing this subject for the 3rd time, but I could not find a care. My problem is ABS fault. Vehicle 2004 307 xt. No esp, only abs. My've done
We changed the ABS brain
All the cables that came to the abs brain and bsi to the motor brain were inserted.
The latest software was thrown into the engine brain
Even the air flow meter was in place, I replaced it with the original (I was supreme on everything)
But still, while driving on the road, it suddenly gives an abs error. I turn off the ignition and I'm getting better. When I connected the vehicle to the computer, the error gave me the error in the picture in the link;
http://hizliresim.com/ybjwol
samet2461 2015-05-03 11:40:09
08.05.2020 19:15 # 2
xmen
I don't know if it has anything to do but it seems to me that the speed sensor is faulty ...
08.05.2020 19:15 # 3
berk2309
My teacher would cut the battery charge, make it more or less, the conjunctor was defective in me.
08.05.2020 19:15 # 4
muro_60
As your friend said, measure your charge, mine was overcharging km indicator malfunction lights were flashing, I said that the connector was burned, it was all okay, no problem.
08.05.2020 19:15 # 5
samet2461
I said to the master that he is a hi sensor, but there is no speed sensor in this car. Sensors on the wheels send signals to the abs, calculate the abs brain and raise the mileage. There is no such thing in this vehicle. Does anyone have any other ideas? I got biked now
08.05.2020 19:15 # 6
samet2461
Let me see it on the conjunctor then. Com2000 would do it on your arm. Because my headlight sensor stays on continuously, the bidet rain sensor does not come on.
08.05.2020 19:15 # 7
Alicilik
Take a look at the ESP tab in the ECu configuration, I think ESP is painfully accidental.
08.05.2020 19:15 # 8
seduray
Is it the same problem mentioned at the address below? He solved the problem by cleaning the cable ...
http://www.307online.com.ar/foro/viewtopic.php?f=16&t=24187
08.05.2020 19:15 # 9
KILIC
[QUOTE = Recipient] Look at the ESP tab in ECu configuration, I think ESP is bitterly mistaken. [/ QUOTE]
I agree.
08.05.2020 19:15 # 10
samet2461
[QUOTE = seduray]
He says it is from the wheel sensor, probably, but I told the master the same. The master said, if one at a time, said which wheel he had on the computer and had a sensor malfunction. I'll take a look at two things that your friends have pointed out. Conjector with esp.
I would appreciate if there is someone who will lead another way. I now want to look at the point as a general, not a malfunction. I no longer really spent money in the world
08.05.2020 19:15 # 11
pusutr
As far as I know, this problem occurs in the connector problem of the starter motor.
08.05.2020 19:15 # 12
ismailkaya
Alternator's job is about to end, and it will leave you on the road
08.05.2020 19:15 # 13
riderzist
[QUOTE = samet2461] Let me look at the conjunctor then. Com2000 would do it on your arm. Because my headlight sensor stays on constantly, the bidet rain sensor does not come on. [/ QUOTE]
he makes it from the gel adhered to the glass on the rearview mirror, you have to change it, but to a beautiful glass master, the glass has changed, I think they threw a shaking gel. I did not touch my hand so I will take the original gel and do it myself
08.05.2020 19:15 # 14
riderzist
I agree that was the first thing that came to my mind
08.05.2020 19:15 # 15
samet2461
[QUOTE = riderzist] [QUOTE = samet2461] Let me see it in the conjunctor then. Com2000 would do it on your arm. Because my headlight sensor stays on constantly, the bidet rain sensor does not come on. [/ QUOTE]
All right, as you say I will take care of him
08.05.2020 19:15 # 16
samet2461
[QUOTE = riderzist] [QUOTE = Reception] Take a look at the ESP tab in ECu configuration I think ESP is painful bias. [/ QUOTE]
I tied it up and looked it off, it looks like it's off. There is no problem in alternatorude olctuler, too, it seems akude good ? How did this not work?
08.05.2020 19:15 # 17
riderzist
[QUOTE = samet2461] [QUOTE = riderzist] [QUOTE = Receiving] Take a look at the ESP tab in the ECu configuration, I think ESP is painful bias. [/ QUOTE]
I tied it up and looked it off, it looks like it's off. There is no problem in alternatorude olctuler, too, it seems akude good ? I don't understand how this works [/ QUOTE]
Is the socket on the brake pedal checked?
08.05.2020 19:15 # 18
samet2461
[QUOTE = riderzist] [QUOTE = samet2461] [QUOTE = riderzist] [QUOTE = Receiving] Take a look at the ESP tab in ECu configuration, I think ESP is bitterly biased. [/ QUOTE]
If you say the mucus, my teacher changed it
08.05.2020 19:15 # 19
msertkol
I must change your battery and have a look at your charger. Electronic problems are caused by batteries in our vehicles. If not, install a new battery, even for trial purposes, and try to see if there are any errors.
Best regards.
08.05.2020 19:15 # 20
Mevlut
How many km is the speed burning like 80 90? And what brand of fault detector do you have the same codes on the Abs brain? There are many reasons
Page : / 4
