Those who make gasoline and sound like diesel |
| 08.05.2020 14:11 | # 1 |
when the vehicle warms up, a tremendous click is nobody could find what it is 2000 model 1.4 206 do you have the same problem |
| 08.05.2020 14:11 | # 2 |
Onur |
they didn't find mine either
| 08.05.2020 14:11 | # 3 |
What will happen is that there is something like this?
| 08.05.2020 14:11 | # 4 |
Those who understand from the engine will give the necessary answer. The first time I heard petrol running like diesel, I saw diesel running like gasoline ![]() |
| 08.05.2020 14:11 | # 5 |
[QUOTE = Honor] couldn't find mine, well [/ QUOTE] You did not believe when I was loving :)
| 08.05.2020 14:11 | # 6 |
Onur |
You said there is nothing, brother, but when it stops in the lights or something, that voice will get annoyed. |
| 08.05.2020 14:11 | # 7 |
kocvizyon |
yeah mine is diesel but don't believe if i work like gasoline :))
| 08.05.2020 14:11 | # 8 |
fuel quality is the biggest factor especially in octane knocking, it is seen more in lpg vehicles, it makes sound when it is clicked.
| 08.05.2020 14:11 | # 9 |
My friend, I have the same problem, I did it before, but after a while I saw the same sound, how I made it, while doing the master, I saw my car gasoline + lpg, there was springs in the cover where the spark plug made the spark plugs. but then as I relax, the spring sounds like a diesel car, the problem you will understand is resolved temporarily.
| 08.05.2020 14:11 | # 10 |
It works a little noisy in my car. More than 49 thousand. No problem in the engine. but it works with a sound close to it, although not as much as diesel. I used the injector cleaner of würth on the internet. It was good in terms of injector health, and the engine sound of the vehicle was significantly thinner. I advise. ![]() |
| 08.05.2020 14:11 | # 11 |
He said the same behind me when I didn't notice. I think if the car is diesel :)) let me show you. Maybe there is a problem with the exhaust pipe. what science is not an idea I understand here. Two more vehicles at 50,000. and although all 10,000 maintenance is done at the service. I just got it. the lady owner before me had it done. I saw it from the booklet, all stamped and signed by the service. Anyway, I will take it. |
| 08.05.2020 14:11 | # 12 |
[QUOTE = maverick] is running a little noisy in my car. More than 49 thousand. No engine problem. but it works with a sound close to it, although not as much as diesel. I used the injector cleaner of würth on the internet. It was good in terms of injector health, and the engine sound of the vehicle was significantly thinner. I advise. ![]() [/ QUOTE] How and where did you use it?
| 08.05.2020 14:11 | # 13 |
As far as I know the adjustment is distorted in 1.4 8 valves, the valve adjustment may be required and the injector may be
