Those who change solenoid because of the knock? |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 16:34 | # 1 |
note: please also write the model and year of our vehicles. |
| 08.05.2020 16:34 | # 2 |
djchaos |
http://forum.peugeotturkey.com/forum_posts.asp?TID=17000&title=otomatik-anzman-da-vuruntu the topic was opened about this problem if you want to see it |
| 08.05.2020 16:34 | # 3 |
In fact, there are many titles on this subject, I just opened this title to make the pre-post impressions of those who made this change seem tidy.
| 08.05.2020 16:34 | # 4 |
yes I have changed it has been 1.5-2 years & nbsp; I also wrote in the forum. the problem did not repeat, I did not have any problems, then everything is normal. |
| 08.05.2020 16:34 | # 5 |
fTh206 |
I also changed it 3 months ago what is knocked, nothing else or even the gear shifts are not felt too soft.Also, he told me that if you make sudden and hard launches in automatic geared vehicles, he said that you will encounter the same problem again after 1 month. :) :) |
| 08.05.2020 16:34 | # 6 |
It would be nice if we write down how many models (which year) the vehicles are. for example, were your models over 2006? or was it the old case? For example, I have a new safe. There is a new type of solenoid. still knocking slightly. Is there any point in replacing old solenoids with new ones, even if there are problems? As you write to understand this, it would be more useful if you write how many models your vehicle has.
| 08.05.2020 16:34 | # 7 |
As he wrote in the signatures, Fatih 2007 is my 2005 model |
| 08.05.2020 16:34 | # 8 |
hi guys i have 2005 xt 307. I replaced solenoids in December. however, sometimes there is a slight hard knock. but when the weather is good, there is not much knock. I have a new type of solenoid attached & nbsp;
| 08.05.2020 16:34 | # 9 |
fTh206 |
[QUOTE = nightfly] hi friends I have 2005 xt 307. I replaced solenoids in December. however, sometimes there is a slight hard knock. but when the weather is good, there is not much knock. I have a new type of solenoid attached & nbsp; [/ QUOTE] When the weather is cold, knocks occur in me, I think it is not something to be worn so much, it does in the cold |
| 08.05.2020 16:34 | # 10 |
Does the knock have anything to do with the cold weather?
| 08.05.2020 16:34 | # 11 |
2003 sw 307 vehicle 1 year ago, I changed the oil of the gearbox with new valves.When the winter enters the engine is cold, sometimes knock is sometimes on the screen & nbsp; automatıc gear fault error. AND WARNING MODE LIGHTS never happened. Everything is normal when the engine is warming up. I'm waiting for the air to warm up.
| 08.05.2020 16:34 | # 12 |
I changed the solenoids in the authorized service about 10 months ago. There is no problem for now.
