those that licking the sump bolt
08.05.2020 14:05 # 1
tugrabozan
As a result of a new development in gasoline and diesel engines, it is now possible to drain oil with suction (no pipe).
Draining is carried out through the dipstick guide, which is plunged to the bottom of the crankcase.
The tip of the bar guide has a wide mouth (2 diameters: 14 and 16 mm relative to the motors), so that it can be attached to the tool that allows suction and discharge.
WARNING: this type of drain should never be used in engines for which no such application is intended; In some cases, due to the shape of the bottom of the crankcase, the oil deposit is extremely high (about 1 liter).
1 - LIST OF ENGINES WITH SUCTION AND EMPTYING
engine type Vehicles � joint bushings (mm)
TU9 - TU1 - TU3 106 - 206 - 306
PARTNER
14
TU5J4 106 14
TU5JP4 306 - 406 14
TUD5 106 16
XU7JB 406 14
XU7JP4 306 - 406 14
XU10J4R 306 - 406 - 605 - 806 14
XU10J4RS 306 S16 14
DJ BOXER 16
DK 605 16
ES9J4 406 - 605 14
ES9J4S 406 - 607 14
EW7 406 14
EW10 206 - 406 - 607
806 - EXPERT
14
EW12 406 - 607 14
DW8 206 - 306
PARTNER - EXPERT
14
DW10 206 - 306 - 406 - 607
806 - PARTNER - EXPERT
14
DW12 406 - 607 14 `` excerpt ''
08.05.2020 14:05 # 2
ErkanKurnaz
nice sharing, health brother in your hands
