This tool will drive you crazy (HELP)
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 16:38 # 1
Meric42
I am satisfied with everything, from speeding up to fuel consumption, even a car that I love. but their suspension seems a bit stiff. And every time I go on the road, I get scabies up to the sound coming from my luggage, I officially wear it on my head. I do not know the name of friends, but I lowered the plastic in this trunk, changed the plastics there, the sound was cut slightly, but it seems as if the trunk is swinging big. I think it comes from the key part .. I would be very happy if someone could help. Swaying lightly in the trunk. The only sound in the car! MY CAR 2005 PARTNER 5 DOORS
08.05.2020 16:38 # 2
Ali
There is a 2011 Partner Tepe Outdor.
I bought Zero. > Since the vehicle is 1500 kg and a heavy vehicle, the suspension is a bit stiff.
My advice; See if the tire is loose, or grease the door locks. The sound will be cut off.
08.05.2020 16:38 # 3
Meric42
thank you for your help immediately lubricantcam.suspension is hard as if it provides a bit of grip but like i said it will annoy the baggage sound
08.05.2020 16:38 # 4
dynamic07
If the tailgate is squeaking, there are 2 rubber wedges on the right and left side when you open the trunk, the trunk sound will be cut off if you loosen them slightly above the rear stops and take them out.
dynamic07 2012- 03-10 14:15:21
08.05.2020 16:38 # 5
dynamic07
Did you handle the problem, what is the result?
08.05.2020 16:38 # 6
sarp
jack cover loose, my voice is coming from there, I got all the doors on it, it was not cut anyway, I realized later, my brother was using it, I traveled in the trunk, the cover that hides the jack on the right is swinging my 2006 1.9
