This problem has run out my life
08.05.2020 19:27 # 1
maestro
I haven't been able to get rid of this sound for years, I thought I changed all the cups 1 month ago, when I heard again, I changed the oil pump by saying that the oil pressure is insufficient today, there is no sound there, I can not tell how much my morale was disturbed when the car got hot and the car has an idea. It starts when the heat is proportional to pressing the gas becomes frequent or diluted.
08.05.2020 19:27 # 2
talip206
If there is an LPG, it can make a lot of sound according to the model of the LPG brand. Crank pulley can also be controlled
08.05.2020 19:27 # 3
maestro
Sounds when you turn off the LPG, not from the LPG
08.05.2020 19:27 # 4
maestro
[QUOTE = maestro] When I turn off the LPG, not the Lpg, the sound comes and the motor comes from the motor, whichever master listened, he said the cup including the ones in the service, even the last year, 2 cups were changed in the service, the others were not very healthy, I said that the others were broken, now I have changed all of them, but the sound continues.
08.05.2020 19:27 # 5
oguz41
The quality of my master oil is also made with its thinness thickness. I changed this sound in my ford car before. 16 valves cut the oil when I put 5.30 castrol new generation.
08.05.2020 19:27 # 6
nevce
I think it's definitely a crankshaft pulley even as a result
08.05.2020 19:27 # 7
maestro
[QUOTE = oguz41] The quality of my master oil is also made with thickness thickness. I changed this sound in my ford car before. 16 valves cut oil when I put 5.30 castrol new generation. 5 30 Doesn't it make more sound than a thinner fat, did it sound when your sound was cold or warm?
08.05.2020 19:27 # 8
maestro
[QUOTE = nevce] I think definitely the crank pulley even happened to me as a result
[/ QUOTE] I had experienced the problem of the crank pulley before the air conditioner or something, especially a squeak happens like this different sewing machine, it makes a sound like a fence, a roof, and a sound like a motor.
08.05.2020 19:27 # 9
staticxxx
Could you change your motor oil for your mobile 3000 x1 5w40 and write the result?
08.05.2020 19:27 # 10
maestro
[QUOTE = staticxxx] Could you change your motor oil of your mobile 3000 x1 5w40 and write the result? there must be another part that will be repaired
