This 5 cd player will drive me crazy ..
08.05.2020 13:58 # 1
sedat23
Friends, this is the peugeot company that has put the cd players to test the patience of the drivers. It has not worked properly since I bought it or it lights the lights on. I tried a lot of CDs when I insert the cd on the screen it says normal but it doesn't read cd
08.05.2020 13:58 # 2
There should be a reset button on the back of the device, if it is difficult to plug in the device, remove the fuse, after 60 seconds, replace it.
08.05.2020 13:58 # 3
sedat23
I changed the pressure pad of the car recently, the battery was removed, after the repair, I turned on the radio, it was working.
08.05.2020 13:58 # 4
hasimayaz
if you have a good electronic knowledge. It may be useful to lubricate the impellers with liquid silicone and clean the sensors with pure alcohol. But this process requires serious mechanical and electronic knowledge
08.05.2020 13:58 # 5
sedat23
sensor just changed 2.3 months ago
08.05.2020 13:58 # 6
sinan-s
The cd cahnger unit of the 307s quickly breaks down.
08.05.2020 13:58 # 7
sedat23
The man who did it last time when I made it was 200 TL, I regret that I did not sell
08.05.2020 13:58 # 8
sedat23
[QUOTE = DERAN_TUYNER] There should be a reset button on the back of the device, if it is hard to plug in the device, remove the fuse, it is the most practical solution after 60 seconds ... [/ QUOTE]
I opened the fuse box, but I could not disassemble the fuse, I could not play it in such a place. When it comes to the CD player, there is no tool to remove: :(
08.05.2020 13:58 # 9
[QUOTE = sedat23] [QUOTE = DERAN_TUYNER] There should be a reset button on the back of the device, if it is hard to plug it in, remove the fuse, after 60 seconds, put it back in. The most practical solution is ... [/ QUOTE]
He has a solution with the PeugeotTurkey Difference SmileSmile
First we take a metal hanger and turn it into U shape.
WITH THE WIRE WIRE OF OUR BUKTU, WE SURCE TO THE HOLES AROUND THE UNIT.
Image reduced to 71.25% of its original size. Click this bar to restore to full size.
WE REMOVE U WIRE BY PRESSING AGAIN
THERE SHOULD HAVE 2 U-BARS AND DO IT FROM TWO SIDES AT THE SAME TIME.
08.05.2020 13:58 # 10
sedat23
Ooo, I'll try it as soon as I find a super hanger :)
08.05.2020 13:58 # 11
There is a hanger varya ...: D
08.05.2020 13:58 # 12
sedat23
last cd was left I got angry in it, I put the big tweezers on the first eye, I took a piece came with the pieces: D
08.05.2020 13:58 # 13
[QUOTE = sedat23] I was pissed in the last cd.
Then you say no, don't work, no hangs LOLLOLLOL
Even a little brother, take a sledgehammer with you again. LOLLOL
08.05.2020 13:58 # 14
HakanGokdemir
[QUOTE = DERAN_TUYNER] [QUOTE = sedat23] I was pissed in the last cd left.
LOLLOLLOL
08.05.2020 13:58 # 15
sedat23
But brother is not as you know :) it does not get mad, for example, before this time it was broken, it did not give 1,2,3,4 cd, but it did not give only 5 works, now it does not play the cd but all eyes are taking the cd comfortably and it is completely unreasonable.
08.05.2020 13:58 # 16
hasimayaz
[QUOTE = sedat23] But the brother is not as you know :) it does not officially go crazy, for example, it did not give it when it bought 1,2,3,4 cd before this time it was broken, it was only 5 works, now it does not play the cd but it is completely irrational event [ / quote]
Don't press the contact while the cd player is running .. I have a similar problem. When the cd presses the contact while it is running, it starts kicking. It works properly when you remove and insert the cd.
hasimayaz 2008-11-13 16:15:50
08.05.2020 13:58 # 17
sedat23
I usually pay attention to it, but the device still does something in a certain amount of time.
08.05.2020 13:58 # 18
sedat23
I could not disassemble the CD player, but I removed the fuse, I waited for a while, I inserted the CD player again and the date and time settings on the road screen were broken, blinking, but I cannot change it Tongue
08.05.2020 13:58 # 19
TOLGA
plug a pioner, let your head run out Big 20smil% to
08.05.2020 13:58 # 20
sinan-s
[QUOTE = Serhat amount] went well, hang up varya ...: D [/ QUOTE]
LOLLOLLOL
Page : / 2
