think peugeot 206 turbo intercooler
08.05.2020 16:25 # 1
lew40
He said, "I was abroad, I had a heavy maintenance in 206, now I found a turbo master." But I guvenemiorum piston parts die What do you say? & Nbsp;
08.05.2020 16:25 # 2
MagicPerformance
forget the healthier piston -crank and arm-main bearings break the engine over 210 hp
08.05.2020 16:25 # 3
Ucyuzalti
The engine should be made of turbo resistant parts & nbsp; forgen piston .. vs & nbsp; let's put it anyway whatever you say if the turbo breaks down we change it another & nbsp; "LOL" Three hundred six 2011-12-04 23:27:17
08.05.2020 16:25 # 4
lew40
As you said, the engine stays in my hand, the problem with the atmospheric engines. The ceramic clutch plate is also considered. Vehicle (206 Gti S16) & nbsp;
08.05.2020 16:25 # 5
MagicPerformance
Atmospherically best specs for 206 gti:
2.2 intake manifold, 2.2 throttle, good brand headers, complete straight pipe, a solid end silencer, with these eccentric applications, you get 170-180 hp from this ceramic clutch set by the way we can not find light flywheel and ceramic clutch set need me, I would be glad if you help with this :) :)
08.05.2020 16:25 # 6
lew40
There is a complete straight pipe and end silencer. 2.2 Which engine can I find the 2.2 intake manifold from the throttle? Is there a pejo or citroen, so does an engine option? I can find the ceramic clutch set. I had my previous vehicle, xsra vts de all power on asphalt;) & nbsp;
08.05.2020 16:25 # 7
MagicPerformance
[QUOTE = lew40] Complete straight pipe and end muffler. 2.2 Which engine can I find the intake manifold, 2.2 throttle? Is there a pejo or citroen, so a motor option? I can find the ceramic clutch set. I had my previous vehicle in xsra vts de all power on asphalt;) & nbsp; [/ QUOTE]
You can find 2.2 suction and butterfly from 406 coupe :) Can you get me a price for the light flywheel and sports clutch set for 206 gti tr? . Member
08.05.2020 16:25 # 8
lew40
The 406 coupe has a 2.2 hdi engine, Gti a & nbsp; is this? I will see the price for the clutch set as soon as possible. I will send it to you as soon as possible.
