THEY DO NOT SOLVE ANTIPOLLUTION ERROR !!!
08.05.2020 20:29 # 1
barisnikof
Hi
Since I bought my 2004 307 vehicle, that is, I have not been able to solve the antipollution fault and sometimes the antipollution fault catality convector fault error in the lpg I have been living for about 1.5 years.
the vehicle has incredible vibration, shaking you know, and then an error message
Coil and spark plugs changed 2 times.
injectors were cleaned, software was discarded.
throat butterfly was cleaned and calibrated.
it does not disappear. Thumbs Down
any other suggestions?
barisnikof 2017-08-03 10:17:42
08.05.2020 20:29 # 2
Well, the inside of the floor must be filled and my teacher must try oxygen sensors. and look at the map sensor.
08.05.2020 20:29 # 3
whisky
[QUOTE = barisnikof] hi
[/ QUOTE] Sir, I get the error from the LPG, the head is already in the head. is not giving the error anyway.
08.05.2020 20:29 # 4
barisnikof
[QUOTE = sonerkyl] Well, it is necessary to try oxygen sensors on the floor of my teacher. and look at the map sensor. [/ QUOTE]
There was no operation about the sensors, when I went last, I asked him if he could be with the sensors.
Now I'm going to take the lpg. unless
08.05.2020 20:29 # 5
barisnikof
[QUOTE = whiskey] [QUOTE = barisnikof] hi
[/ QUOTE] Sir, I get the error from the LPG, the head is already in the head. is not giving the error anyway. [/ QUOTE]
I get the lpg from the same place or even from the same station from the shell
When it comes to low speed, I use it at low speed. just to be less :)
let me touch the gas now
08.05.2020 20:29 # 6
I think the master shook well. If the oxygen sensor and map sensor have soot pollution, they cannot read the data. I think it has to be removed and cleaned. meanwhile, the floor may be full.
08.05.2020 20:29 # 7
Karacocuk24
Soner says right, the master shook my cousin 406 was giving the same error, inserted the catalyst and tried the silencer 1 day it turned out again burned the error then switched the oxygen sensor 2 I think there was nothing left, I think, look at the oxygen sensor with the map, you may have done a lot of other operations already. Karacocuk24 2017-08-03 22:31:14
08.05.2020 20:29 # 8
Furkan979
The first time I bought it was such a problem when I gave the antipollition error, the car was reluctant calkiyo titriyod I got the application as obd2 from the internet, I deleted that error and after I deleted it, I always bought gasoline from the same place, I have never had a problem for 5 6 months. I bought it from opet, I bought it from a different place once again, I bought it again before the warehouse was over.
08.05.2020 20:29 # 9
whisky
[QUOTE = Furkan979] The first time I bought in me was such a problem. When I gave the antipollition error, the car was reluctant calkiyo titriyod, I got the application obd2 from the internet. I always buy gasoline LPG from opet, I bought it from a different place because it was cheap. I started using it in this way. If it burns once in a while, I delete the error from LPG. It is very rare. I always get it from the same pump or even the same pump.
08.05.2020 20:29 # 10
barisnikof
When I get an error, I put the vehicle on gasoline. I use 10 minutes.
then it turns out when I turn the ignition off and on again.) Then I take the LPG and continue.
but it trembles
08.05.2020 20:29 # 11
barisnikof
yeah friends thank goodness solved ...
this morning I went to my mechanic to replace the coil
"My brother, I will not take your money in the morning and morning, there is nothing to ignite in your coil. Go to LPG."
there was zavoli (zavoli in my car too) they worked more than half an hour to find the error, they found that the 3rd injector C lpg was broken.
they changed and thank goodness. it was like clockwork.
It cost 180 TL.
I have already done it on the hair, and the problem is resolved in some way if we come across the competent and well-intentioned mechanic.
08.05.2020 20:29 # 12
onlycihan
Let's get past, if we make an application like this in the forum. how can we share the places and phones of the masters and services that we recommend to each other that are visited and satisfied in each province :)? If we reach real people who are not pile-holders rather than door-to-door, we can save time and cash.
