they couldn't turn off the fault lamp
08.05.2020 15:57 # 1
riva70
For a long time, we found that the vehicle (2004 pug 307 1.6 manual) engine malfunction lamp was lit by lpg (atiker multifast) (failure code p0171 poor wife) I made several adjustments in the moment, but in vain I went to the atiker service in osmaniye, we said okay, we made it about half an hour He made the finest adjustment, he said, if he lights up again, he said there is no solution. now my dear lamp is on again, is there any way to put it out?
thanks
riva70 2011-08-28 14:46:38
08.05.2020 15:57 # 2
vbmaster
This topic has been discussed many times before. I am still not able to get LPG because of this topic. after all, I can say that. Is it not burned? LPG also. Unfortunately, it is impossible to look at the master if there is always a master of the master.
08.05.2020 15:57 # 3
riva70
now i am in ottoman
the central dealer of the center of the assistant in konya says let us make the setting from here, but not here.
Atiker LPG master is wanted in Osmaniye and its surroundings.
08.05.2020 15:57 # 4
metin
I believe that multifast is not compatible because it is old, but I am very satisfied as someone who uses safe fast.
08.05.2020 15:57 # 5
riva70
oldest kit fast they say they want 500tl to wear it they say it may not burn then the room doesn't make sense to me
08.05.2020 15:57 # 6
vbmaster
kits the same software is changing 500 lira what is beh :) yuh now ....
08.05.2020 15:57 # 7
riva70
the brain and a few more pieces said that we will almost do the same with the new assembly
08.05.2020 15:57 # 8
riva70
I went to the dealer of Atiker again, damn it!
08.05.2020 15:57 # 9
[QUOTE = vbmaster] I have talked many times before, this subject is still not able to get lpg because of this topic. after all, I can say that. Is it not burned? LPG also. a master who wears it, couldn't replace it, shame, all you have to change the system is unfortunately but it is impossible to look at the master's master, but it is impossible in Iğdır conditions ... [/ QUOTE]
There is no such thing as burned out. When I bought my car, the malfunction lamp was on, but now it is not lit.It did not reach 10 in 2 years, the lamp was on and it turned off by itself. Now it is off.
There is nothing to do with it, my friend, the malfunction of the malfunction lamp, no matter how you set it up, does it want to light up, it burns.I have a poor way, 10 thousand of them have been maintained 2 months ago. for.
1) Definitely do not change the lpg brand. Even if possible buy from the same station.
2) Use your vehicle at regular intervals on gasoline.
08.05.2020 15:57 # 10
riva70
I have not tried the LPG brand, I bought it from the same place, but it did not disappear.
But I burned, the man's nerve is falling, the ears of the man who made that lamp ring
08.05.2020 15:57 # 11
metin
then the man you go does not understand the setting. If it burns in LPG, it is a rich mixture or a poor mixture. The solution for this is a good setting. but if I remember correctly, your vehicle's fuel is higher than normal.
08.05.2020 15:57 # 12
[QUOTE = text] then the man you go to doesn't understand the setting. If it burns in LPG, it is a rich mixture or a poor mixture. The solution for this is a good setting. but if I remember correctly, your vehicle's fuel is higher than normal. [/ QUOTE]
When the mixture fails, the vehicle kicks, the traction drops and the fuel increases.
Atiker is a problematic kit ... Stew of cheap meat ..
08.05.2020 15:57 # 13
metin
[QUOTE = laedri] [QUOTE = text] then the man you go to doesn't understand the setting. If it burns in LPG, it is a rich mixture or a poor mixture. The solution for this is a good setting. but if I remember correctly, your vehicle's fuel is higher than normal. [/ QUOTE]
I think brother is not a problem kit. I will be for 1 year since 13.000 km I did not turn on the malfunction lamp once. I am very pleased with its fuel and traction. so mastery is important, not an aiker or x brand.
08.05.2020 15:57 # 14
[QUOTE = text] [QUOTE = laedri] [QUOTE = text] then the man you go to doesn't understand the setting. If it burns in LPG, it is a rich mixture or a poor mixture. The solution for this is a good setting. but if I remember correctly, your vehicle's fuel is higher than normal. [/ QUOTE]
You are right, the master is also very important.
08.05.2020 15:57 # 15
riva70
the fuel is a little too much in the traction, the water is kicking from time to time after the last settings.
08.05.2020 15:57 # 16
riva70
I just looked, the lamp is extinguished by itself, no, I hope we will see when it will burn again
08.05.2020 15:57 # 17
vbmaster
Hodja, that lamp goes out and your eyes go there all the time, or I know how nervous you are.
08.05.2020 15:57 # 18
UGuRs
CENGİZ MAKİNE LPG is the dealer where you go, at the same time they sell it in the vikars. Don't go there.
08.05.2020 15:57 # 19
metin
[QUOTE = UGuRs] CENGİZ MAKİNE If LPG is the dealer where you go, they also sell it in the vikars. Don't go there .
one more bad so-called master Gülme
08.05.2020 15:57 # 20
riva70
i went to osmaniye small industry valiant autogas
Let's see now the lamp is dimmed 20 km.
The kit is still under warranty, don't they replace it with safe or safefast obd? Under guarantee
Page : / 3
