Thermostat failure
08.05.2020 18:05 # 1
halilefe
Hi Üdatdat My car peugeot 206 hdı I know where there is a thermostat malfunction.
Last week, I changed the antifreeze even though I went for a distance of 100 km, the indicator remains below 70, and if I leave the vehicle running, I wait 10 minutes, but it does not exceed the bottom line. Is the problem from the thermostat?
08.05.2020 18:05 # 2
halilefe
actual
08.05.2020 18:05 # 3
Serkan
If the thermostat is malfunctioning, the engine does not turn on at all, or the engine does not turn off. The engine runs very cold. Serkan 2013-11-26 14:29:52
08.05.2020 18:05 # 4
kursat3006
I think the trouble should be on the indicator? Is that a hot air heater?
08.05.2020 18:05 # 5
halilefe
There is no problem in the heating system, you went to the master, he said that the thermostat is defective without measuring the temperature. Tongue
08.05.2020 18:05 # 6
kursat3006
I don't understand if the heater is hot or not
08.05.2020 18:05 # 7
halilefe
Hot blown sister
08.05.2020 18:05 # 8
kursat3006
As far as I know, if the problem is in the thermostat, there is no hot air coming from the heating, if there is a mistake, friends can fix it or it is impossible to get hot air when the temperature is not rising.
08.05.2020 18:05 # 9
Keep the temperature officer in mind.
08.05.2020 18:05 # 10
halilefe
Normally my vehicle travels 420-450 km with a 100 TL diesel, this time it went 300 km, so I was suspicious from the thermostat or threw raw gas, because it could not be heated.
08.05.2020 18:05 # 11
reklames
I have the same problem, brother. the master noticed while doing another problem. the thermostat said bad and changed. But he didn't notice anything. I wonder why it's low. If it's information, I'd be happy to share it.
08.05.2020 18:05 # 12
ahmed206
Keep in mind that you can add thermostats, circulation pumps, and customers to your timing changes. My head was not comfortable, I will go to the industry again later. I picked up the pieces at the appropriate time.
