There was a noise in the vehicle, but help. |
| 08.05.2020 20:04 | # 1 |
Selox |
Hello friends; There was a sizzle from the clutch part of my vehicle. I went to the industry is simple. He looked at the sound, listened to the back of the engine and did something behind the engine where the full hydraulic oil was, and the sound went away. it happened as if it had slipped. what do you think? it may also benefit other friends. ? Could it be about egr pump? As if I need to reactivate :) |
| 08.05.2020 20:04 | # 2 |
sonerkyl |
No, if my brother egr has been canceled, he will not make a sound. your manifold tampered around there.
| 08.05.2020 20:04 | # 3 |
ggitaristt |
the shield plate hits a locality and makes a sound, bent it slightly. ![]() |
| 08.05.2020 20:04 | # 4 |
Selox |
um. that is, at the back of the intake manifold. In the bodywork facing the driver's seat. No guitarist, brother. Even if it corrects it, it takes at least 5 minutes. The man held out his hand and took care of the back :) It wasn't like that. he knew the sizzle :) he knew it was close to the clutch as zzzz :) It was strange that he understood and solved the problem immediately. Couldn't delete P0403 code? |
| 08.05.2020 20:04 | # 5 |
Selox |
The lamp does not light up but there is a computer connected to it?
| 08.05.2020 20:04 | # 6 |
sonerkyl |
P0403 EGR CIRCUIT FAILURE Check the sockets or was it canceled if your egr is canceled it is not deleted due to your room.
| 08.05.2020 20:04 | # 7 |
Selox |
| 08.05.2020 20:04 | # 8 |
ggitaristt |
Brother I always think of the simplest breakdown. I was also sizzling, while the oil was changing at certain times, the man put his hand from the bottom and the sound was cut in 5 seconds. If it's running smoothly, look at the car tamper ![]() |
| 08.05.2020 20:04 | # 9 |
Selox |
| 08.05.2020 20:04 | # 10 |
Selox |
Friends that sound was coming from the egr valve. sizzle. I put the plug in the place where I showed that picture and the sound goes. I am using the plug now. In some departures, it doesn't seem to stop eating gas, it seems like it stops, I press the clutch again and continue after stopping. Do you think the egr valve needs maintenance? I guess that error is not deleted for this reason. Like you said. |
| 08.05.2020 20:04 | # 11 |
sonerkyl |
teacher, they do egr cleaning but generally users prefer to cancel egr.
| 08.05.2020 20:04 | # 12 |
Selox |
What do you think are the benefits and harms? What is your opinion. They say fuel increases?
| 08.05.2020 20:04 | # 13 |
OguzhanKucuk61 |
This is also happening with me. Especially like uphill crackling after 3000 cycles uphill. There is a sound like oil frying in a pan. Why does this happen? Is it the same with yours?
| 08.05.2020 20:04 | # 14 |
Selox |
No, it's not the same, brother. It may be that of your motor ear. I say look. The motor may be shaking. It would be a suitable start for you financially. It can be the 2nd turbo propeller. |
| 08.05.2020 20:04 | # 15 |
OguzhanKucuk61 |
We eliminate the vehicle's 1.4 petrol teacher turbo option. What kind of trouble can it sound if the sound we are talking about is in the motor ear? Is it an important issue?
| 08.05.2020 20:04 | # 16 |
Selox |
It is not important at first stage, but it may cause trouble. After all, the connection of the engine to the case. If the ear is broken, it will swing more than necessary and may cause distress. I think show it. I think the master can understand the engine by shaking it. But I am not saying that it will be necessarily. It would be a practical solution. This kind of sizzling situations can also be evaluated from the exhaust. |
| 08.05.2020 20:04 | # 17 |
OguzhanKucuk61 |
Let me tell the master about the situations you said and take a look. No excessive noise in case of any shaking or idling in the engine. It only does uphill at high rpm. And another matter is this; When I sit a bit too fast on the 4th and 5th gears at low speed, at low speed, it sounds like a turbo. Why is that, hodja? |
| 08.05.2020 20:04 | # 18 |
Selox |
The car drowned at low speed is normal. After 2000, they are relieved.
| 08.05.2020 20:04 | # 19 |
OguzhanKucuk61 |
I know thanks. But I do not use much under 2000. The car is not drowning when I have the voice I mentioned. I'm not staying at that lower cycle. When I press a little more gas than usual, there is a sound like a vacuum cleaner. |
