THERE IS TOMORROW EXAMINATION?
08.05.2020 17:41 # 1
superyusuf
friends mrb. tomorrow examination, can you give information on what i will write down below?
5 cm eibach sports bow
headlights foiled
windows with film
ceiling carbon
tires not original 165/70/13 195/45/15
what are you saying
08.05.2020 17:41 # 2
emre_akdag
my humble opinion:
5 cm eibach sports bow - heavy flaw
headlights foiled - slight defect
windows with film - slight defect
ceiling carbon - slight flaw
tires not original 165/70/13 195/45/15 - no trouble.
my experience is so .. of course if you inform us after you return :) it would be great :)
08.05.2020 17:41 # 3
rolandgarros
then the springs have to come out as far as I understand?
08.05.2020 17:41 # 4
Zagorka
Yes Must Quit
08.05.2020 17:41 # 5
superyusuf
[QUOTE = expert_emre16] humble idea:
I experienced it, next to the dios. Come on dear ya.
08.05.2020 17:41 # 6
superyusuf
6.2.1 Front spring (s): broken Heavy Defect 15.01.2012 31.12.2070 1 2 4 5 6 7 8 6.2.2 Front spring (s): damaged Heavy Defect 15.01.2012 31.12.2070 1 2 4 5 6 7 8 6.2.3 Front spring (s): vehicle too close to the ground Light Defect 15.01.2012 31.12.2070 1 2 4 5 6 7 8 6.2.4 Front spring (s): lower clearance not sufficient Light Defect 15.01.2012 31.12.2070 1 2 4 5 6 7 8 6.2.5 Front spring (s): suspension hardware displaced Light Fault 15.01.2012 31.12.2070 1 2 4 5 6 7 8 6.2.6 Front spring (s): spring bowl tight Light Fault 15.01. 2012 31.12.2070 1 2 4 5 6 7 8 6.2.7 Front spring (s) air tube (s) / air bellows (s): leaking Light Flaw 15.01.2012 31.12.2070 1 2 4 5 6 7 8 6.2.8 Front spring (s) air tube (s) / air bellows (s): damaged Slight Defect 15.01.2012 31.12.2070 1 2 4 5 6 7 8 6.2.9 Front spring (s) air pipe (s) / air bellows (s) Next): bearings are worn Light Defect 15.01.2012 31.12.2070 1 2 4 5 6 7 8 6. 2.10 Front spring (s) air tube (s) / air bellows (s): incorrectly adjusted Light Defect 15.01.2012 31.12.2070 1 2 4 5 6 7 8 6.2.11 Front stabilizer: improperly installed Light Defect 15.01.2012 31.12 .2070 1 2 4 5 6 6.2.12 Front stabilizer: damaged Slight Defect 15.01.2012 31.12.2070 1 2 4 5 6 6.2.13 Front stabilizer: broken bearing Slight Defect 15.01.2012 31.12.2070 1 2 4 5 6 6.2. 14 Front stabilizer: no Light Defect 15.01.2012 31.12.2070 1 2 4 5 6 6.2.15 Front stabilizer: no torsion limitation Light Defect 15.01.2012 31.12.2070 1 2 4 5 6 6.2.16 Front spring (s): spring pins / fork loose Light Defect 15.01.2012 31.12.2070 1 2 4 5 6 7 8 6.2.17 Front spring (s): damaged Light Defect 15.01.2012 31.12.2070 1 2 4 5 6 7 8
08.05.2020 17:41 # 7
superyusuf
I have shared friends see b. light flaw diy.I found this excel table on the net
08.05.2020 17:41 # 8
Aziz
According to the list you gave, there is no problem.
08.05.2020 17:41 # 9
emre_akdag
then there is no problem Yusuf dude :) let's see ..
08.05.2020 17:41 # 10
driver_can
I went with 5 cm eıbach bow 195-45-r16, they did not write any defects on them.
08.05.2020 17:41 # 11
There was no problem before, my friend entered with air suspension, there was no problem on examination
08.05.2020 17:41 # 12
Bugra
[QUOTE = superyusuf] 6.2.1 Front spring (s): broken Heavy Defect 15.01.2012 31.12.2070 1 2 4 5 6 7 8 6.2.2 Front spring (s): damaged Heavy Defect 15.01.2012 31.12.2070 1 2 4 5 6 7 8 6.2.3 Front spring (s): vehicle too close to the ground Light Defect 15.01.2012 31.12.2070 1 2 4 5 6 7 8 6.2.4 Front spring (s): the bottom clearance is not sufficient Light Defect 15.01. 2012 31.12.2070 1 2 4 5 6 7 8 6.2.5 Front spring (s): suspension hardware displaced Light Fault 15.01.2012 31.12.2070 1 2 4 5 6 7 8 6.2.6 Front spring (s): spring bowl tight Slight Defect 15.01.2012 31.12.2070 1 2 4 5 6 7 8 6.2.7 Front spring (s) air pipe (s) / air bellows (s): leaking Slight Defect 15.01.2012 31.12.2070 1 2 4 5 6 7 8 6.2.8 Front spring (s) air tube (s) / air bellows (s): damaged Light Defect 15.01.2012 31.12.2070 1 2 4 5 6 7 8 6.2.9 Front spring (s) air tube (s) ) / air blower (s): bearings are worn Light Defect 15.01.2012 31.12.207 0 1 2 4 5 6 7 8 6.2.10 Front spring (s) air tube (s) / air bellows (s): incorrectly adjusted Light Defect 15.01.2012 31.12.2070 1 2 4 5 6 7 8 6.2.11 Front stabilizer : not properly mounted Light Defect 15.01.2012 31.12.2070 1 2 4 5 6 6.2.12 Front stabilizer: damaged Light Defect 15.01.2012 31.12.2070 1 2 4 5 6 6.2.13 Front stabilizer: broken bearing Light Defect 15.01.2012 31.12.2070 1 2 4 5 6 6.2.14 Front stabilizer: no Slight Defect 15.01.2012 31.12.2070 1 2 4 5 6 6.2.15 Front stabilizer: no torsion limitation Slight Defect 15.01.2012 31.12.2070 1 2 4 5 6 6.2.16 Front spring (s): spring pins / fork loose Light Defect 15.01.2012 31.12.2070 1 2 4 5 6 7 8 6.2.17 Front spring (s): damaged Light Defect 15.01.2012 31.12.2070 1 2 4 5 6 7 8 [/ QUOTE] the examiner has a very bad head on the springs. what is this
08.05.2020 17:41 # 13
sercinho
brother, I came with bow and exhaust otto spech, nothing came out of the bow, I just put the slanter on the way of the exhaust, and I passed the room, they wrote a piece that is not suitable for the exhaust,
08.05.2020 17:41 # 14
SDYMZ
If there is a coating on the ceiling, there is no problem.
08.05.2020 17:41 # 15
fatihgg
[QUOTE = sercinho] brother, I entered with bow and exhaust otto spech, nothing came out of the bow, I just put the slanter on the exhaust, and I passed the room, I wrote a piece that is not suitable for the exhaust, I think you will be comfortable with the bow
I agree exactly, last year, I saw that there was a spring + silencer in Istanbul. mild defect due to unsuitable ones :) spring was no problem.
08.05.2020 17:41 # 16
Aziz
what is the result? It was evening did not write yet?
