there is sound in gear shifts
08.05.2020 19:55 # 1
ahmet3642
friends, easy. I have a 2005 model 407 2hdi automatic gear car. It does not matter in summer and winter. In the mornings, after the first take-off, there is a noise in the gear changes. what could be the reason for this?
08.05.2020 19:55 # 2
OguzhanKucuk61
Transmission and vehicle not yet warmed up. My 206 gear is already bony, as you say before it warms up, it makes a loud noise
08.05.2020 19:55 # 3
First of all welcome, Mr. Ahmet. So when did the car's last gearbox oil and filter change?
08.05.2020 19:55 # 4
ahmet3642
There was no such problem before. Started this winter
08.05.2020 19:55 # 5
ahmet3642
It's been a year since I have never changed the transmission oil.
08.05.2020 19:55 # 6
My teacher may have several reasons for this.
1-gear oil and filter have not changed for a long time. or it may be due to a decrease. (250-500 tl) oginal filter Over 200 tl, sub-industry around 100 tl oil expensive lt
2-brake sensor can cause such problems. (25-30 TL) You can even change your cat.
3-worst case, selonoidk valves may need to be replaced. Between 700-1000 TL
08.05.2020 19:55 # 7
ahmet3642
Thanks
08.05.2020 19:55 # 8
[QUOTE = ahmet3642] thank you thanks [/ QUOTE]
you are welcome good forums.
