There is sound even when I go over Stone
08.05.2020 20:50 # 1
GiTaRRa
friends, my problem is strange, the front layout is not very much done, but I get a strange notice sound. In a small bump of sound, the main shape of the sound is coming to the stone. gitarre 2018-04-18 01:24:32
08.05.2020 20:50 # 2
KILIC
Is your car 106 or 206? It may be from torsion.
08.05.2020 20:50 # 3
GokhaN
Actually, if we hear the sound, we say something better. If you can shoot a video, add a check.
08.05.2020 20:50 # 4
GiTaRRa
The vehicle 206 friends come in front, not torsion.
08.05.2020 20:50 # 5
onlycihan
My friend, I recommend you to check the brake pads. The springs that fix the pads fall over time, or some triggers do not wear at all. On such serrated roads, the pads are idle and they hit the discs, making strange annoying metal sounds. the onlycih 2018-04-19 17:30:32
08.05.2020 20:50 # 6
GiTaRRa
I am suphe of the shock absorbers, but thank you.
08.05.2020 20:50 # 7
KILIC
Do you have steel rims in your vehicle? The hub of the rim can also make such sounds. But if you take a video and upload the video as Gokhan says, it may be easier to interpret it.
08.05.2020 20:50 # 8
GiTaRRa
[QUOTE = KILIÇ] Do you have steel rims in your vehicle? The hub of the rim can also make such sounds. But the most robust is that it can be easier to interpret if you shoot a video like Gökhan said. [/ QUOTE]
Look, this may be the master, the shock absorber did not release solid oil, and the tires came in the mutabin, and this sound may be among the possibilities, but should I change the wheel hub? If you shoot a video, you can not get it clear, but it is a thin voice, but in the night above the stone, with a loud voice ..
