There is something strange in the vehicle
08.05.2020 17:58 # 1
blazes06
Greetings to all, my 206 Quiksilver vehicle is in the 2nd gear between 4-5 thousand revolutions and there is a situation in the vehicle, such as zigr flickering (limping), and I do not know why this flickering is caused by the knocks on the gear lever. In other gears, the situation is normal. Nothing like throwing out of gear. The pressure changed 5 months ago. I just changed the oil in the gearbox, no sound, etc. I can think of it, but it has to shake it in other gears. I am waiting for your suggestions for a clear situation.
08.05.2020 17:58 # 2
Barut
Makes from engine chocks or axle
08.05.2020 17:58 # 3
blazes06
Let's go to repair early tomorrow morning. I forgot to write, when the bottom gas starts to load, it feels up to the vehicle's chassis. Let's see if we get out of the pile without eating ...
08.05.2020 17:58 # 4
Barut
the same thing happened to me, we changed the axle with the engine chock, we had a good pile Big smile
08.05.2020 17:58 # 5
I think, from the ax, my teacher, go first, show a rot to the balancer, he will make you see what the lineage is and what it is
08.05.2020 17:58 # 6
fthusl
the same problem is me doing the 4th gear at 2500 rpm and then cutting it Confused
08.05.2020 17:58 # 7
Bunyamin.Kar
Hodja go directly to the rotbalancer, take the test drive, tell the situation
08.05.2020 17:58 # 8
blazes06
Problem solved. Right Front axle inner race is broken.
08.05.2020 17:58 # 9
[QUOTE = blazes06] Problem Solved. Right Front axle inner race is broken. [/ QUOTE]
I'm glad you could solve it. At least he made the same mistake constantly and diagnosis was easier.
There are also unfortunate people like us,
Voook vooook sound was coming from the left front of the car, and after a while, the sound disappeared after 5 minutes, and after a while, vook vook sounded again for 5 minutes. The sound continues until he goes to the mechanic. When it came to the repairman, the sound was cut off. I went to the repairman 3 times in 3. the voice disappeared. We left the last car to the master (master). I said, there is gas in the evening, go home with it in the evening. Man coincided with the first day, the problem from God was on the balls ^^
