There is snow on the vehicle;)
08.05.2020 16:32 # 1
rhcpeppers
friends, there is heavy snow on the vehicle. I tried to clean it, but my hand was frozen. There is light in the icing. not the kind of easy to melt. If I pour salt, will it be harm & nbsp;? Or what would you recommend.
08.05.2020 16:32 # 2
Sonmez
hot water:)
08.05.2020 16:32 # 3
06OzGuR06
No hot water warm & nbsp; becomes water. "Wink" Room temperature water.
08.05.2020 16:32 # 4
yavuz25
[QUOTE = rhcpeppers] friends there is heavy snow on the vehicle. I tried to clean it, but my hand was frozen. There is light in the icing. not the kind of easy to melt. If I pour salt, will it be harm & nbsp;? Or what would you recommend. [/ QUOTE]
pour out the salt, then make an appointment with a good painter, if I have a car to be painted, how much you paint it. Embosses. It is a type of salt that causes body decay. Where does your mind come from interesting ideas. "Big "
08.05.2020 16:32 # 5
yavuz25
[QUOTE = 06EZGÜR06] No hot water warm & nbsp; becomes water. "Wink" Room temperature water.
Even if you connect a hose to the tap and open water. But if the weather is cold, I think it is not necessary because it will freeze again.
08.05.2020 16:32 # 6
06OzGuR06
[QUOTE = yavuz25] [QUOTE = rhcpeppers] friends there is heavy snow on the vehicle. I tried to clean it, but my hand was frozen. There is light in the icing. not the kind of easy to melt. If I pour salt, will it be harm & nbsp;? Or what would you recommend. [/ QUOTE]
pour out the salt, then make an appointment with a good painter, if I have a car to be painted, how much you paint it. Embosses. It is a type of salt that causes body decay. Where does it come to mind, interesting ideas. "Big "
"LOL"
08.05.2020 16:32 # 7
rhcpeppers
where do I get the water at room temperature, let me go to the car;) let me have a water in gasoline & nbsp; the best
08.05.2020 16:32 # 8
yavuz25
[QUOTE = rhcpeppers] where to take the water at room temperature, let me go to the car;) let me have a water in gasoline & nbsp; best [/ QUOTE]
freezes again, the size of the disaster will grow as water will enter everywhere. Apply petroleum jelly or antifreeze glass water to the wicks of the doors you will open. "Wink"
08.05.2020 16:32 # 9
06OzGuR06
[QUOTE = yavuz25] [QUOTE = rhcpeppers] where do I get the water at room temperature, let me go to the car;) let me keep a water in gasoline & nbsp; the best [/ QUOTE]
freezes again, because the water will enter everywhere, the size of the disaster will grow. .But I'll give you a recommendation />
"Thumbs
08.05.2020 16:32 # 10
Alicilik
Put the water in the fist box from the winter liquids put into the glass water and squeeze it into the ice after 1-2 minutes with a rubber eraser & nbsp;
Salt can draw
08.05.2020 16:32 # 11
06OzGuR06
06ÖzGüR06 2012-01-17 19:22:45
08.05.2020 16:32 # 12
yavuz25
[QUOTE = ScHerZo] put the water in the fist box of the winter liquids put in the glass water and squeeze it with a rubber eraser after 1-2 minutes. & Nbsp;
Salt can draw
Salt's scratching will have the slightest effect. Pour salt in the paint for a while and let it dissolve with water. Let's see what happens with the paint. "smileys / smiley17.gif" border = "0" alt = "T o ngue" title = "T o ngue" />
08.05.2020 16:32 # 13
GiTaRRa
would it be salt? It is clear in the mirrors, so I don't care, let's not worry about it:) & nbsp;
