There is oil in the air filter
08.05.2020 20:09 # 1
Mehmet92_27
I have a 307 1.4 16v 2005 model vehicle. There is an event I noticed in the past, there are small colored tanks that come out of the intake manifold and enter the air filter in the small hose and in the mouth of the air filter.
08.05.2020 20:09 # 2
firstly welcome. there is no problem teacher oil steam hose that sweats are happening in general. If there is no other problem, it will be better if you take a photo and send it.
08.05.2020 20:09 # 3
Mehmet92_27
[QUOTE = sonerkyl] firstly welcome. no problem teacher oil vapor hose that sweats like this usually happens if there is no other problem, it will be better if you take a photo and send it. [/ QUOTE]
I will take a picture as soon as I get the opportunity. I cleaned it when I saw it.
08.05.2020 20:09 # 4
no problem like clogging is very difficult, you have to escape into the room, you will leave the room open, but as I said, because it is sweating, it seems more in winter because there is this type of lubrication in my vehicle.
08.05.2020 20:09 # 5
Mehmet92_27
[QUOTE = sonerkyl] no problem such as clogging, it is very difficult, you have to run into the room, you will leave the room open, but as I said, it is more common in the winter due to sweating because this type of lubrication occurs in my vehicle because [/ QUOTE]
You relieved me, thank you someone said that it could be from the top cover, I was annoyed. There is something else. Since the vehicle that is on my head is lpgli, there is a little oil reduction problem.
08.05.2020 20:09 # 6
fat reduction has nothing to do with lpg. Let me tell you from the beginning. I use about 40 thousand km lpg li. It decreases 50-100 ml. Now, how much oil is decreasing in how many thousand km. If there is a lot of oil added, it will be a problem. Check the level on the dipstick.
By the way, this is not the place I marked.
08.05.2020 20:09 # 7
Mehmet92_27
When I bought the vehicle at 149.500 km, it was at 136.000 km, we did the lgp assembly after a thousand km and went 2500 km after the last oil change yesterday morning, the car was showing the middle of the car like half full of oil castrol magnatec 10 40 wiped again But the lower parts of the cube were intense, the upper parts seemed only smeared. I bought a liter of the same oil, yes, my teacher is exactly the places you show in the picture and that oil is filled with the inside of the hose.
08.05.2020 20:09 # 8
mehmet disassemble that part and clean it with a nice wd40 and add 10/40 oil to the vehicle that should be put in 5w / 30 norm but if you observe that oil decrease, let's see if it decreases around 10000 km 0.5 lt - 1 lt thick it is now 5w to the vehicle with thick oil. If you put / 30, you will increase the reduction, first of all, follow the current oil.
08.05.2020 20:09 # 9
Mehmet92_27
In fact, the first time I bought the vehicle, there was 5 30 inside the gasoline while there was no reduction. When LPG was installed, it started to decrease. We put 10 40 on you. let me see what happens, thank you for your interest God bless you
08.05.2020 20:09 # 10
you are welcome I am using 5w40 mobil fully synthetic oil. When the brand of oil is French in total, they suggest each other, dont get mobile 5w30, then put 10w / 40 is 5w / 30 oil which is suitable for your vehicle. 10w / 40 oils are semi-synthetic 5w / 30 oils are fully synthetic oil. full synthetic oil is better. I recommend reading this subject.
http://forum.peugeotturkey.com/forum_posts.asp?tıd=43428&title=motor-yagi-ile-ilgili-bilgilendir Up
http://www.hepsiburada.com/mobil-super-fe-5w-30-benzin-ve-dizel-motor-yagi-4-litre-p-otm652072
08.05.2020 20:09 # 11
Mehmet92_27
[QUOTE = sonerkyl] please I am using 5w40 mobil fully synthetic oil. When the brand of oil is French in total, they suggest each other, dont get mobile 5w30, then put 10w / 40 is 5w / 30 oil which is suitable for your vehicle. 10w / 40 oils are semi-synthetic 5w / 30 oils are fully synthetic oil. full synthetic oil is better. I recommend reading this subject.
I read it, I guess our country is going to be a little hot at 40 degrees.
