There is oil in 206 mats.
08.05.2020 20:42 # 1
Ezmoces
Hello friends. 2004 I have a model 206 vehicle. There were minor problems in the car. For example, there was a stop problem. We changed this kiltotre reader and solved this problem. Even the service was surprised. If we were, I saw the floor wet when I removed the mat on the driver's side. When I wiped it with a wet wipe, it was bluish oil. I wonder if it was steering or brake fluid oil. It was a bit interesting to have oil there. I would be glad if you helped ..
08.05.2020 20:42 # 2
eran
[QUOTE = Ezmoces] Hello friends. 2004 I have a model 206 vehicle. There were some minor problems in the car. For example, I had a stop problem. We changed this kiltot reader and solved this problem. Even the service was surprised by it. If we come to the subject, I saw the floor wet when the driver's side removed the mop. When I wiped it with a wet wipe, it was like a bluish oil. I wonder if it was my steering or brake fluid oil. It was a bit interesting to have oil there.
It looks like antifreeze.
08.05.2020 20:42 # 3
Ezmoces
So how does my coach get there?
08.05.2020 20:42 # 4
my teacher is missing antifreeze from the radiator.
related topic
08.05.2020 20:42 # 5
Ezmoces
About 20 days ago, they changed the radiator radiator. The part of the mat was wet during the change. Even after 20 days, it was wet again.
08.05.2020 20:42 # 6
husem
If he wants, one year, melet is not drying. You will clean it 3-4 times with plenty of detergent and water and take it with a vacuum cleaner that can draw liquid every time. then you will dive with ufo or hair dryer.
There is a honeycomb cover on the right side of the driver's section, there is a foamy sheath that closes it.
I huseyın 2018-01-24 17:51:43
08.05.2020 20:42 # 7
Ezmoces
To the right of the accelerator, yes, there is something like black foam sponge. I hold the lower part with my hand occasionally. Ezmoces 2018-01-25 09:19:00
08.05.2020 20:42 # 8
Ezmoces
Hello again ... I washed the mop of the car with foamy water a few times. Then I dried it with ufo. After a month, I removed the mop today, I still got wet. I even opened the door wick, removed the floor and that part was wet. It seems that there is an error in the person who wears the honeycomb right now.
08.05.2020 20:42 # 9
Exactly, if my master threw a single screw while attaching additionally, the kidnapping should definitely support with a liquid gasket.
08.05.2020 20:42 # 10
onlycihan
If the honeycomb problem is solved, you have the water intake event that happened to me. The adhesive parts of the nylon insulation material inside the doors release themselves for years due to dust and water, and the water drained from the glass wick passes through the doors to the carpet underneath without wetting the mat.
08.05.2020 20:42 # 11
Ezmoces
A friend of mine put a screw on the missing part. The auto electrician said that the setting is broken and put a single screw. It changed in the contour. I raised the temperature to 95 and turned on the fan. Ezmoces 2018-03-14 17:23:31
08.05.2020 20:42 # 12
talip206
To understand that it is from antifreeze, wrap a napkin in the place where the heating section is, use it a bit. If the napkins get wet, it will be obvious already. Apart from that, as our friend of the world says, there is a nylon under the door trim while the speaker or something is changing, it tears. When it ruptures, instead of flowing into the channels, it drifts through and drips under the door plastic. You can understand it by placing a napkin on the part where the flooring and the wick of the door meet.
Another possibility is that water can enter the grille with the wipers on the windscreen side.
08.05.2020 20:42 # 13
Ezmoces
Thank you, my teacher. All of you.
08.05.2020 20:42 # 14
Ezmoces
Guys, the edges of the wick on the bottom of the windshield are well adhered, but the middle part is slightly opened. Is there a possibility of getting water from there?
